FX-8350 build feedback parts list
Iv picked out this setup i would like some feed back
im planing on using the kraken 60 but there out of stock right now thank you
oh I want an amd build
Fractal Design Define R4 with Window Black Pearl Silent ATX Mid Tower Case
Item #: N82E16811352021
Return Policy: Standard Return Policy
$119.99
SAMSUNG Spinpoint F3 ST1000DM005/HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822152185
Protect Your Investment (expand for options)
Recover Your Data(expand for options)
$99.99
ASUS SABERTOOTH 990FX R2.0 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
Item #: N82E16813131877
Return Policy: Limited Replacement Only Return Policy
-$10.00 Instant
$189.99
$179.99
EVGA 02G-P4-3660-KR GeForce GTX 660 Ti 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
Item #: N82E16814130809
Return Policy: VGA Standard Return Policy
$20.00 Mail-in Rebate Card
$299.99
CORSAIR HX Series HX850 850W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
CORSAIR HX Series HX850 850W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC ...
Item #: N82E16817139011
-$30.00 Instant
$189.99
$159.99
Kingston HyperX Beast 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model KHX18C9T3K4/16X
Item #: N82E16820104368
Return Policy: Memory Standard Return Policy
$124.99
AMD FX-8350 Vishera 4.0GHz (4.2GHz Turbo) Socket AM3+ 125W Eight-Core Desktop Processor FD8350FRHKBOX
Item #: N82E16819113284
Return Policy: CPU Replacement Only Return Policy
$199.99
Corsair Air Series AF140 Quiet Edition CO-9050009-WW 140mm High Airflow Case Fan
Item #: N82E16835181028
-$6.00 Instant
$124.95
$94.95
($18.99 each)
NZXT Kraken X40 RL-KRX40-01 140mm Ultra Performance Liquid CPU Cooler
Item #: N82E16835146027
$99.99
ADATA XPG SX900 ASX900S3-128GM-C 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
Item #: N82E16820211596
your partlist does not show up put it in pcpartpicker pls
oh ya amd what is your budget
the link is broken
Yep that looks great!
fixed
budget is 1400 to 1600
these are two experemental builds im working on(im posting here since they seem to fit your price range once you add a hdd/cooling), they're missing hdd and cooling at the moment, looking to prioritize streaming and mutli monitor setup, might be helpful for ideas, or i might just be retarded, either way :p if these builds are bad, any advice would be appreciated :D
http://pcpartpicker.com/p/y9mH
http://pcpartpicker.com/p/yaJ6
you probably dont need an 850 watt PSU unles you plan on some heavy upgrades in the future.
i do, at the very least ill likely be doubling the gpu and running sli/cross
But yeah i shouldent suggest that PSU to someone else, my bad :p
If you've got 1400-1600, you should be able to fit a 7970, or a GTX 680 in there.
Also, change the memory to this instead: http://pcpartpicker.com/part/gskill-memory-f31866c9d16gsr
It runs just as fast, has a CAS of 9, and will save you 30$.
