Yea, currently I have a small rotating fan locked in one direct blowing on the board.
It def is being pushed to throw he power at it, I cannot run higher than 1.325v to the cpu, will not post.
But it dose seem to be running fine with the VRM cooled off. Still gets HOT HOT HOT but I no longer see throttling.
190x22 aka 4.18ghz at 3.13v
prime 95 blend over 50 min, all cores still up and running. CPU no higher than 48.8c but those VRM are HOT 90-97c
I was seeing them 106 then throttled before the fan was ran over the mobo. And keep in mind this is STRESS TESTING!!! idles and does everything else 44-50c
Fact is, I do NOT need the power, I need the cores! I only need to run "idling" windows operations on several virtual machines. And the occasional transcoding and shit. This PC is just a tool for school and once I am working in the field I will build a new PC and throw this in my P180 and update my NAS with a cheaper CPU or underclock the shiz out of it.
I understand where you are all coming from, if I knew beforehand these kinds of boards were just updated to ALLOW the FX processors to run I might have gone with a full ATX board. But I wanted a "small" desktop with the power to do some transcoding quickly and help me with school.
If you still think this is a bum build let me know, but I think you are missing the point, this is a build to run server OS's and virtual networks. The cores will come as a big help and the all out performance is not an concern of mine. I would have gotten a slower 8-core, but it was on sale cheaper than all the other ones.
besides this thread was about my displayed watts in HWiNFO64; which is totally just a misread data feed. There is no way the watts would be a perfect 110.381W 24/7.
Again, I understand now the limitations of the board. But I do not feel I need to update the system. I am not going to buy a new case and mobo just to be able to overclock more or have it run the vrm cooler. It works and will be totally fine with what I need it to do.
just an unemployed your adult going back to online university for a BA in IT. So I needed it cheap. Here is the build... fans still in the mail!
http://pcpartpicker.com/user/BobDole2016/saved/3bYy
