I am currently trying to decide between these 2 CPU's. I can get the FX 6300 with an Asus M5A97 LE R2.0 or I can get the i5 3350p with the MSI B75MA-E33 Matx board.
Which of these 2 combo's would give better performance in video games and emulators especially Dolphin. Or would be better to choose?
Overclocking isn't really a big deal to me... If I overclock the FX 6300 and it still doesn't perform as well as the i5 3350p then whats the point?
If you all have any other suggestions I only have a budget of $230 for a CPU and MoBo so keep that in mind.
both are rely good i have a fx 6300 and it run dolphin emulator just fine what game are you wanting to play i cant test them and tell you if the fx 6300 dos the job so far im running resident evil remake and it run at 25 to 30fps my intel rig performe about the same it can comme down to your preference but if you want a few more fps then go intel since single core performance is better then amd
you can get blasphemous overclocks with a 6300 and that results in it beign well into i5 territory. i would go for the amd as you get a bit more in the mobo department
if you dont want to spend alot in the am3+ get the same board minus the "LE" supposedly it oc's better (i've heard) should cost the same, maybe $5 more
the only difference i see is that the le is missing some heatsinks
take the Asus M5A97 R2.0 if you not gonne play with oc,4+2 power phase. will give you a little space for oc, but not much, but if you turn on, the turbo core it oc's it self to 3.9 ghz so thats nice too.
if you want play with oc then take the Asus M5A97 EVO R2.0 6+2 power phase.
