Hi Everybody,
In spite of watching a bunch of videos on the topic from Steve, Wendell, and Buildzoid, my suspicions have been insufficiently honed by paranoia. I’ve only assembled this thing about a year ago. It’s got the 0x129 microcode. It’s not like I’m running Minecraft servers…
I’d been trying to compile QEMU the past few weeks, here on my i9-13900K computer system. It would keep segfaulting on this line in a configure script, some ninja meson setup etc. No matter what I did, it would crash on that line. I blamed myself. After all, when is PEBKAC ever the wrong answer? I tried reboots, different versions of the Linux kernel, different versions of QEMU, different versions of Meson… It’s some other guy’s build script, confirmed working. Everything else seems fine. How badly could I have broken my Linux installation?
Wait. Intel?
I cobbled together a Bash script so I could watch requested voltages while working. That was inconclusive. They’re mostly under 1.4 volts. Then, when I was trying to build virt-manager, it happened to fail on the analogous Meson line in a similar-enough configure script to the failing QEMU script. On a hunch, I changed the CPU scheduling governor to powersave. Then the build failed in a different spot. I changed it back to performance, its original value, and the build succeeded.
Intel!
The same trick didn’t work with QEMU though. I decided to run y-cruncher overnight, trying to catch my processor red-handeder. I saw that the voltages were lower than in fewer-core workloads, makes sense with probably some overall power or thermal limit, went to bed. About 10 hours later, I checked back in, and saw that the voltages had dropped quite a bit, down from 1.2-1.3V requested to like 1.17V. That’s weird. On a hunch, I tried to compile QEMU again, and this time, out of nowhere, it succeeded. It had been failing consistently for weeks.
Somehow y-cruncher healed the build.
Even if it is ultimately my fault, bad CPU installation a year ago, in the immortal words of Buildzoid, slightly edited,
If it was me, I’d sell the replacement CPU. And the motherboard.
And just like swear off Intel CPUs for like a few years.
You screw me over buy selling me defective trash.
I’m not buying stuff from you anymore.
Thereby, I’m looking for CPU and especially motherboard recommendations. My hard requirements are:
- AMD CPU
- ECC RAM officially supported
- Friendly to my 3 slot tall AMD 7900 XTX GPU
- 8+ SATA ports (or free PCIe slots if needs be)
My currently owned non-Intel parts are:
- Case: Fractal Design Define 7 XL
- Power supply: be quiet! Dark Power 13 1000W ATX 3.0
- RAM: 2x 32 GB DDR5 ECC UDIMM – Micron MTC20C2085S1EC48BA1R
- Drives: 1 M.2 NVMe drive, 6 SATA HDDs (raidz2), 1 SATA optical drive
- GPU: AMD 7900 XTX (3 slots tall)
- CPU cooler: Noctua NH-D15 (might as well keep it)
- IIRC 4x 12V PWM fans and 2x DC
I’m eyeballing a 7800X3D, because of course, but I am curious about alternatives, if they exist. Tentatively, as far as AM5 goes, it looks like either of the X670E or X870E chipsets are likely to give me a good time. X870, according to Wikipedia, only supports x8 PCIe gen 4 lanes. Would that bottleneck me? Or would it be completely irrelevant, in spite of my graphics card’s lack of support for PCIe 5? (or – maybe I’m just misreading a mislabeled table)
Workloads I’m planning on are, playing games, storing / locally hosting files, otherwise generally screwing around with anything that’ll run on it. Probably monkeying around with VMs more over time, whatever tiny AI models will fit, possibly inducing RAM upgrades, SSD upgrades. I keep computers a long time. I’m chasing this dream of having one box for all purposes. You can never cross the same river twice. You can never go home. But maybe you can consolidate on a single computer.
Linux only. Windows in a VM later, maybe, in screaming protest. My long term plan for this machine is to join a death cult so I can persist as an immortal lich over the millennia, long enough to see Microsoft go bankrupt.
Aside, how worried would you be, if you had a deeply convicted religious obsession with data integrity, about the probability of erroneous bits previously committed to disk over the past year?
Please and thank you.
