The ground really does not mater when it comes to the power switch and reset switch, all you have to do is make sure they are connected to the right pins. Ignore the color of the wires, just make sure that the you plug them into the right pins.
the speaker plugs say 5v+ ground ground and speaker. (4pins total) but the case came with a tiny speaker that only has 2 wires one red and one black meaning the 2 middle holes dont have any wires.
the case manual does not refference neither that speaker wire nor the other front pannels headers.
It dos not matter either which way you install it as long as it is in the correct pins. I just tried on my intel system and the speaker worked either way, so you can not mess up ;)
Hey john i just turned the pc on and it works every fan works except when i get to the american megatrends page it says cpu fan error and it beeps 3 times
Looks like you should power your pc down, turn off the back of the power supply and reseat your ram. Then we can go from there and see if we can narrow it down.
Go into your BIOS, and look around for it. You should be able to choose boot priority device from there to install your windows, and while you are there take a look at your CPU temps and make sure all your ram is detected as well as your hard drive.
Turn off the pc, plug in the USB drive and start it up. KEep pressing F8, it should take you to a boot choosing screen and you can boot from the USB flash from there.
