Adubs
I ran the rufus created MX-23.4_x64.iso usb. Got to the point of some sort of âwhat do you want to do nextâ semi-graphical menu. could move up and down. Unsure of how to proceed, so went away for a while. When I came back, the screen was still visible but locked.
It was at this point that I did the full safe mode boot and let it idle. This froze after about 28 min.
I assumed that this meant it was not a configuration error, but hw.
In uefi I reset the bios to system defaults. I think previously I had altered an xmp setting for memory. Still crashes.
Opened up the case and vacuumed away dust. All fans spin easily. Nothing untoward about the mb. It holds 4 identical mem sticks, a cpu w/a big cooling fan, and the gpu. It also has my boot ssd flat against the mb. But in reality, w/only the cpu-cooler and gpu sticking out it looks relatively empty compared to previous builds Iâve seen.
As the gpu seems the most swap-testable item, I thought to do that. Unfortunately, the only other functional computers in the house both have gpuâs that require more connections than my power supply provides, so I canât readily swap those different GPUs in to rule it the 2070s
Having passed the mem test, I assumed that meant the memory couldnât be the issue. Also, just to reiterate, while the mem test lasted longer than an hour, It didnât freeze/crash at all. That alone initially made me think the problem was not hw.
At one pt, I thought that the time between crashes was longer when I was playing w/the mouse/keyboard. Now, I think that was just my imagination.
The only reference I found to C-states in the pdf you provide tells only this:
Global C-state Control (Note)
Allows you to determine whether to let the CPU enter C states. When enabled, the CPU core frequency will be reduced during system halt state to decrease power consumption. (Default: Enabled)
I could try that out, but I donât understand how reducing cpu core frequency during system halt states could possibly reduce the number of crashes.
