Hey all, Been looking to improve the storage solution and implement a backup solution. I think FreeNAS is what I want to run but can be persuaded to upgrade to a full server OS if needed. The use case should help figure what I need.
The Use Case
- Current setup is 3 gaming PCs (windows 7) and multiple tabs/phones and 1 smart TV.
- Focus is primary for gaming PCs backups for OS and Data
- One Desktop is OS/Few games SDD with Data/Games HDD the other two are OS and Data on HDD.
- Plan is to have 512gb SSD and 2TB HDD in each machine but limit to 2TB per machine for backup purpose.
Each user has their own AV libraries, some personal AV and some commercial stuff, so will centralise all commercial AV to NAS for streaming purpose, personal Data stays on machine and has backup in form of system image (think they are called system images)
So far in terms of storage 3 * 3TB in ZFS with 1 Disk for parity covers my sytems, might go for 4 tb drives
If I understand backups right, if reasons then I can boot advanced mode and restore my full system from a back up (time is taken) but snapshots/shadowcopy allows me to go into a back up "file" and manually grab files/folders from that back up (hence point in time back up?). This is AMAZING and I NEED this :D.
Questions
- My OS is on SSD, a steam library is on SDD whilst steam installation and other part of library is on HDD, is this going to cause me a headache? In Terms of backup and being able to restore a back up if one drive fails and needs to be replaced.
- I want to stream my data library to devices, FreeNAS can run PLEX so I can play with that, but for data backup I have a headache. Redundancy and Backup, since our AV files will be moved to this one place I need them backed up, I know RAID (which is not what ZFS is) is not a back-up it wont stop accidental deletion or virus. I want to have about 8TB storage for AV files and I want them backed up, whats the best ways to go about this? Having data storage in a NAS that is backed up in the NAS but not in the way that is vulnerable to virus/accidental deletion.
- Least important but if possible: I run a mumble server on my rig and occasionally a space engineers/dedicated game server, can FreeNas handle this or is that a different OS needed?
- The Power supply I have not researched at all, it was going to be the same as Linus's build but the SFX they recommended has bad reviews for noise where ever I looked, Any recommendations?
Build
C2750D4I Intel Asrock Mini ITX Motherboard
2* Crucial CT102472BD160B 8GB DDR3 PC3-12800 Unbuffered ECC 1.35V 1024Meg x 72
Silverstone SST-DS380B - SST-DS380B External 8x 3.5" SAT Hot-Swap ; 4x 2.5"
be quiet! BN227 - Be Quiet! BN227 SFX POWER 2 Power Supply (400 Watts) 80 Plus Bronze
