Last week I got an error message saying bad sectors so replaced the drive. The resilvering process took over 100 hours. Then after a restart yesterday freenas started resilvering again. So I left it and this morning when I checked. There were now these error messages
ada7 2 currently unreadable
(pending) sectors
ada5 2 currently unreadable
(pending) sectors
ada3 ATA error increased from 4 to
10
Ada3 is the drive I’ve recently replaced.
This is the status log
[root@freenas ~]# zpool status -v
pool: J******
state: ONLINE
status: One or more devices is currently being resilvered. The pool will
continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
scan: resilver in progress since Tue Jun 8 22:06:40 2021
1.32T scanned out of 15.2T at 26.6M/s, 151h48m to go
166G resilvered, 8.72% done
config:
NAME STATE READ WRITE CKSUM
Jarvis ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/4fd0edac-5eb8-11e5-8317-d050996490b6 ONLINE 0 0 0
gptid/e0cc7676-18ed-11ea-b434-d050996490b6 ONLINE 0 0 0
gptid/50aecb0b-5eb8-11e5-8317-d050996490b6 ONLINE 0 0 0
gptid/934bee96-c498-11eb-b843-d050996490b6 ONLINE 0 0 0 (resilvering)
gptid/51904b0f-5eb8-11e5-8317-d050996490b6 ONLINE 0 0 0
gptid/5202b9d8-5eb8-11e5-8317-d050996490b6 ONLINE 0 0 0
gptid/5275d7e4-5eb8-11e5-8317-d050996490b6 ONLINE 0 0 0
gptid/52ee6b39-5eb8-11e5-8317-d050996490b6 ONLINE 0 0 0
errors: Permanent errors have been detected in the following files:
/mnt/J*******/Media/Movies/E********/E********.mkv
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0h3m with 0 errors on Fri Jun 4 03:48:35 2021
config:
freenas-boot ONLINE 0 0 0
gptid/a6612988-8d5e-11e6-aa3b-d050996490b6 ONLINE 0 0 0
errors: No known data errors
System spec
Freenas 9.10.2-U6 (booting from usb stick)
CPU intel atom c2750 2.4GHz
ECC Ram 32711MB
8 WD Red 3TB HDD
Any help would be greatly appreciated and sorry if I’ve posted this in the wrong neck of the woods
Thanks in advance
Based on what I could find out, there are no 3TB SMR drives from Western Digital, so this should not be an issue. The CPU is a bit weak, but given that you only have 3TB drives I am wondering why the resilvering process is so slow.
FreeNAS shouldn’t try to resilver again unless maybe the drive dropped out of the array or failed during the first resilver task. What are you using for a hard drive controller? SATA ports on the motherboard or HBA or something else? Using a backplane? If the drive drops out of the array, that would explain the unexpected resilver. It might cause weird drive issues as well such as the unreadable errors… if you haven’t backed up your data from your pool yet, I strongly recommend you do so. At least until you figure out what is going on.
After a lot of digging around I think the problem is the new drive. The majority of the 3TB drives are 6 years old with the EFRX model number and are CMR drives. The new one is a EFAX drive which is an SMR.
As for the connections all the drives are connected to the motherboard. Via the caddy holders.
The resilver time was never as bad as this when I’ve replaced drives before, today it topped out at 150 hours
The server it’s self is only used to feed media and store back ups of work. Everything is already backed up off site on HDD drives if the worst happens
Glad it might help - I didn’t think of it either, moved a drive to another caddy, then created a pool on the potentially faulty caddy and voila, errors. Before that I changed the sata cable .
