Okay so randomly going to a yard sale I found this Dell Optiplex 755 for $10.
Specs: Intel Core 2 Duo 2.33GHz
1GB DDR2
Slim DVD Drive and a media card reader
No HDD (for who knows what reason)
Some ATI card I that I still can not identify. Here is a picture of the ATI card and has what looks to be a DVI connector but does no have the usual DVI interface we are used to seeing.
Well what could I do this machine? I ran Mint on it for the hell of it to see if it was still working and no problems, but could not see if the video card is functioning since I don't have proper DVI cable to fit.
oh nice, that sounds like fun, I have been wanting to mess with a hackintosh but have not gotten around to getting parts. Thank you for the suggestion.
That's an old dual monitor connection. *googles exact name* DMS-59. It uses an adapter that splits off into two connections. They used them a bit a few years back to keep from having to place two full inputs on the backplate of the video card. It was a space saver. I don't remember ever seeing them outside of an office setting though. Don't think they were terribly popular in home use... or at least I never saw any on a home computer.
Oh yeah I found that out earlier from another forum with a very similar card as the one I posted and purchased this adapter here
Hope to do some more testing with this little PC when the adapter arrives. I only got into computer back in 2013 so I am very intrigued by older hardware regardless if it runs less efficient.
another note. i had an old 755 and the cooler was quite loud. i ordered a rosewill off of newegg for like 14 bucks. it was as quiet as a mouse. but when the caps blew on that intel made board, i took the fan and mounted it as an egress fan in a case. it fit perfectly.
Well if you have no other use for it go ahead. But it was something a couple of friends did a couple years back where they shaved the PCB to be flush with the TIM and then used a drill bit to create a small hole through it.
Should be a decent little setup, though and ignifigant overclocking is likely out of the question due to the motherboard Dell likely put in there, and what I'm sure is a fairly low powered PSU... But dump some more ram in her, add a HDD and it should work well for a HTPC/retro or indie gaming setup, a file/media/web server or just a spare low end gaming PC for when friends come over or whatever.
I had an old C2D setup that I gave to my mom years back. It's running Ubuntu like a champ as her daily driver to this day. So those outdated setups still have purpose.
