Fostex FE126En repair
I have a speaker that the connector has been busted.The plastic part that holds the metal connector has been broken.Can anyone repair this with the correct OEM part ? Thank you My email is
[email protected]
Thank you !!!
Rick at Audio Force
Looking at pictures online, it may be as simple as getting a thin plastic strip (from packaging), riveting spade terminals to it and soldering the coil leads to the rivets.
