Hi Logan!
Thanks for putting up the $600 KYC build.
http://www.youtube.com/watch?v=nvpMv52JTqQ
Before I continue, this thread is not meant to show anyone up. I'm bringing this discussion to the table because I believe that the $600 KYC Build could possibly be better with the FX-6300.
What are your thoughts on this?
On my previous thread below, I was wondering what kind of non-APU based build you would come up with for $500.
https://teksyndicate.com/forum/inboxexe/logan-500-gaming-pc-update/153992
I've kept a close eye on the 750k, and I was excited when you brought it up in your $600 build. As an overall build, a system with the 750k allows for flexibility in budget since prices will be different in various parts of the US.
However, as I previously stated, I do believe that the build could be better with an FX-6300.
Prices will not be the same later down the road, but below is just a general idea of what I came up with as of 10-13-13.
http://pcpartpicker.com/p/1OeQr
Total: $610.85
For selected merchants, I've picked only Newegg, NCIX, and Amazon since these are the only three online stores I've actually purchased from. The price above reflects the total with no taxes, combo discounts, promotional discounts (excluding promotional gift cards), and no rebates.
I personally suffer from 7% tax from Newegg and Amazon (as of July 2013), so something like this would not fit my budget since I would be approximately $50-$60 over-budget. In this case, I would probably do something like this.
http://pcpartpicker.com/p/1OftJ
Total: $579.31.
Same settings as the previous build, except with 7% taxes from Newegg and Amazon.
I know that there are people in the US who have worse taxes than I do, but even then, I believe it's possible to assmble a $600 build with the FX-6300.
Again, what are your thoughts on this, Logan?
