Flashing c930c with c930e firmware?
I also have the same problem. I’m glad I read the comments here regarding the modification of the LogiCapture.exe.config file. It works! I uploaded the file at,
drive.google.c0m/file/d/1i7UG-QXfiNci5VpctyMYPCgRuyN8YT0r/view?usp=sharing
Saved it inside the C:\Program Files\Logitech\LogiCapture\bin\
Hi
Can you upload again the config file? it seems it is not for share anymore.
Is it enough to change this file, since I’ve noticed a few entries in the registry involving chinese PID as 0x0891.
Txs
Can you make a Youtube video of this? My Humble Plea
Can you make a youtube video of the solution? Not really a tech savy. Thanks in advance.
Hello guys, please could anybody make that video? How to replace PID and VID ID’s and how to make it in the APP? Many thanks.
Thanks for suggesting, but how did you manage to find the file at the zh-ch site? I cannot find it.
Thanks for the suggestion. I would likely be able to follow the instruction, but for me it is the “Logitech Camera Settings” App that does not recognize/acknowledge the presence of a C930c. Would there be a similar hack? Tried to search for a config file, but didn’t find one.
Thanks. That worked wonders to get the camera into the app
For those who didn’t understand:
  1. Download the file from the link provided above.
    You need to change the number “0” in .c0m to a letter “o”
  2. Navigate to C:\Program Files\Logitech\LogiCapture\bin\ and delete or rename “LogiCapture.exe.config” and put the file you downloaded from the link above in this folder.
You can now use the C930c in the LogiCapture app
awesome solution guys. I just got a new web cam, had seen discussion of this issue before I bought, and luckily stumbled into this very simple cool solution. thanks.
Thank you, thank you, thank you…my frustration is gone!
OK This may not be as elegant but it sure works fine and recognised C930c if you don’t mind the Chinese characters. EU drivers not easily found from Au or lots of dead ends searching Windows 10 and Mac Drivers
Just wondering, any hardware/performance differences between the c and e models other than the light flash feature and the Chinese regulatory compliance and menus which people have mentioned here? I see that the e model is some 20% more expensive in most territories …
Happy to learn as I need to gear up on wide angle cams for a project.
** I’ll be using Ubuntu as the operating system, typically logitech peripherals work quite seamlessly on linux, and I don’t see any concern there …
I’m trying to gather insight on whether the c model is really an equivalent other than some configuration menus that have been mentioned here, which will not be available nor necessary on linux anyway.
Hello, can someone tell me, where can I find this config file on Mac? I would like to update that xml, so I can use Logitech Capture on Mac (on PC it works).
Thank you
According to the Chinese Logitech Support Site:
C930e 是针对美国和欧洲发布的地区限定版本,而 C930c 仅针对中国地区。目前,C930c 版网络摄像头没有可用的固件更新,但它可以顺畅搭配视频会议程序使用
which translates to
C930e is a region locked version for the United States and Europe, while the C930c is only for China. Currently, there is no firmware update available for the C930c version of the webcam, but it can be used smoothly with video conferencing programs.
