Does anyone know how I would go about burning a flac file to a cd? without lowering the audio quality by doing the obvious and converting it to mp3 first.
If you want it playable on dumb CD players, use software like CDBurnerXP and choose Audio CD option. Then it will convert and burn it in proper format.
If you don't care about that, just burn files as is.
Thank you, this looks like it will probably work. I was looking to play them on my old stereo system so, yeah, a dumb cd player
