This concerns issue with newer Linux Kernels + Systemd where Wacom or other graphics tablet shows up as a joystick device and is not recognized by x.
I encountered this recently and it took me quite a while to figure out.
Thanks systemd!
Also if you’re a Linux wacom user, please by all means use KDE with the kcm-wacomtablet-frameworks addon. There is no comparison between this and any of the other linux wacom tools. It blows the clear out of the water.
To fix add the following file to your /etc/udev/rules.d directory and reboot.
/etc/udev/rules.d/99-fix-wacom.rules
# udev rules for libwacom supported devices
# This file is generated by libwacom, do not edit
ACTION!="add|change", GOTO="libwacom_end"
KERNEL!="event[0-9]*", GOTO="libwacom_end"
# Wacom Intuos2 12x12
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0044", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Intuos Pen Small
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="030e", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="030e", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Cintiq Companion
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="030a", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="030a", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="030a", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom ISDv4 E3
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00e3", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00e3", ENV{ID_INPUT_TOUCHPAD}="1"
# Wacom Intuos Pro L
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0317", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0317", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0317", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos4 6x9
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b9", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b9", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos4 4x6
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b8", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b8", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos3 4x6
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b7", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b7", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos3 9x12
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b2", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b2", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos2 12x18
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0045", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Intuos3 12x19
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b4", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b4", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos3 12x12
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b3", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b3", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos2 6x8
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0042", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Intuos3 6x8
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b1", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b1", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos3 6x11
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b5", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b5", ENV{ID_INPUT_TABLET_PAD}="1"
# Huion H610 Pro
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="256c", ENV{ID_MODEL_ID}=="006e", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="256c", ENV{ID_MODEL_ID}=="006e", ENV{ID_INPUT_TABLET_PAD}="1"
# Huion H610 Pro
# Wacom Intuos Pro M
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0315", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0315", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0315", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos Pro S
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0314", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0314", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0314", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom ISDv4 10F
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="010f", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="010f", ENV{ID_INPUT_TOUCHPAD}="1"
# Wacom Intuos3 4x5
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b0", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00b0", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom ISDv4 10D
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="010d", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="010d", ENV{ID_INPUT_TOUCHPAD}="1"
# Wacom Bamboo 16FG 4x5
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00de", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00de", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00de", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos5 M
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="002a", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="002a", ENV{ID_INPUT_TABLET_PAD}="1"
# Huion H610 Pro
# Huion H610 Pro
# Wacom ISDv4 4004
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="4004", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="4004", ENV{ID_INPUT_TOUCHPAD}="1"
# N-Trig Pen
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="1b96", ENV{ID_MODEL_ID}=="0001", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="1b96", ENV{ID_MODEL_ID}=="0001", ENV{ID_INPUT_TOUCHPAD}="1"
# Wacom ISDv4 116
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0116", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0116", ENV{ID_INPUT_TOUCHPAD}="1"
# Wacom ISDv4 5002
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="5002", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="5002", ENV{ID_INPUT_TOUCHPAD}="1"
# Bamboo One
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0069", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom ISDv4 5000
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="5000", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="5000", ENV{ID_INPUT_TOUCHPAD}="1"
# Wacom ISDv4 E6
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00e6", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00e6", ENV{ID_INPUT_TOUCHPAD}="1"
# Wacom ISDv4 E5
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00e5", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00e5", ENV{ID_INPUT_TOUCHPAD}="1"
# Wacom ISDv4 E3
# Wacom Cintiq Companion Hybrid
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0307", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0307", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0307", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Cintiq 13HD
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0304", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0304", ENV{ID_INPUT_TABLET_PAD}="1"
# Intuos Pen & Touch Medium
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0303", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0303", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0303", ENV{ID_INPUT_TABLET_PAD}="1"
# Intuos Pen & Touch Small
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0302", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0302", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0302", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom DTU1031X
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="032f", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Bamboo Pen
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00d4", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Cintiq 22HD touch
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="005b", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="005b", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom ISDv4 93
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0093", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0093", ENV{ID_INPUT_TOUCHPAD}="1"
# Wacom Bamboo 2FG 4x5
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00d1", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00d1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00d1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom DTU-2231
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00ce", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom ISDv4 90
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0090", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Cintiq 21UX2
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00cc", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00cc", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Cintiq 27QHD
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="032a", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Cintiq 27QHD touch
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="032b", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="032b", ENV{ID_INPUT_TOUCHPAD}="1"
# Wacom DTU1141
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0336", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0336", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos5 touch M
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0027", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0027", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0027", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Bamboo 2FG 6x8
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00d3", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00d3", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00d3", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Bamboo Craft
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00d2", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00d2", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00d2", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos5 S
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0029", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0029", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos5 touch L
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0028", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0028", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0028", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom ISDv4 101
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0101", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0101", ENV{ID_INPUT_TOUCHPAD}="1"
# Wacom ISDv4 100
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0100", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0100", ENV{ID_INPUT_TOUCHPAD}="1"
# Wacom Intuos5 touch S
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0026", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0026", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0026", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos 12x18
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0024", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Intuos 12x12
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0023", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Intuos 9x12
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0022", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Intuos 6x8
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0021", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Intuos 4x5
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0020", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Bamboo 2FG
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00d0", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00d0", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00d0", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom ISDv4 12C
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="012c", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom DTU1031
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00fb", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00fb", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Cintiq 22HD
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00fa", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00fa", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos4 WL
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00bc", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00bc", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos4 12x19
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00bb", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00bb", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos4 8x13
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00ba", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00ba", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom DTH2242
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0059", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0059", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0059", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom ISDv4 93
# Wacom DTK2241
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0057", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0057", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom ISDv4 90
# Wacom Cintiq 12WX
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00c6", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00c6", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Cintiq 20WSX
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00c5", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00c5", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom DTU-1931
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00c7", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Graphire4 4x5
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0015", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0015", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Graphire3 6x8
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0014", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Graphire3 4x5
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0013", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Cintiq 24HD
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00f4", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00f4", ENV{ID_INPUT_TABLET_PAD}="1"
# Intuos Pen Medium
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0323", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0323", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom DTF-720
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00c0", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom DTU-1631
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00f0", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Intuos2 9x12
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0043", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Cintiq 21UX
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="003f", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="003f", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Cintiq 24HD touch
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00f8", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00f8", ENV{ID_INPUT_TOUCHPAD}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00f8", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom ISDv4 EF
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00ef", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Wacom Intuos4 WL
# Wacom ISDv4 ED
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00ed", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00ed", ENV{ID_INPUT_TOUCHPAD}="1"
# Wacom ISDv4 EC
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00ec", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Finger", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="00ec", ENV{ID_INPUT_TOUCHPAD}="1"
# Wacom DTI520UB/L
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="003a", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="003a", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos2 4x5
ENV{ID_BUS}=="usb", ENV{ID_VENDOR_ID}=="056a", ENV{ID_MODEL_ID}=="0041", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
# Match all serial wacom tablets with a serial ID starting with WACf
ENV{ID_BUS}=="tty|pnp", ATTRS{id}=="WACf*", ENV{ID_INPUT}="1", ENV{ID_INPUT_TABLET}="1"
ENV{ID_BUS}=="tty|pnp", ATTRS{id}=="FUJ*", ENV{ID_INPUT}="1", ENV{ID_INPUT_TABLET}="1"
LABEL="libwacom_end"
# Wacom Graphire Wireless
ENV{PRODUCT}=="5/56a/81/*", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{PRODUCT}=="5/56a/81/*", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos4 WL
ENV{PRODUCT}=="5/56a/bd/*", ENV{ID_INPUT}="1", ENV{ID_INPUT_JOYSTICK}="", ENV{ID_INPUT_TABLET}="1"
ATTRS{name}=="* Pad", ENV{PRODUCT}=="5/56a/bd/*", ENV{ID_INPUT_TABLET_PAD}="1"
# Wacom Intuos4 WL
