I am looking at Corsair Obsidian 500D as it seems quite decent looking and fairly low cost. One issue is that I need dual 3600m rads support as that’s what I have already.
I did measure the spacing by using the spacing between fan bolts to map the relative dimensions between my rad and picture on screen. It does seem to fit even with thick corsair fans as in stock pictures.
Does anyone have this case and could maybe verify? The top plate for dual fans would need to be replaced but that’s hackable. Maybe the front plate would fit? If not I could just cut out a rough frame out of some think sheet of metal I have, not ideal but it should work fine once installed.
Any alternative suggestion/options are welcome as well!
