Just because it can doesn't mean it's good for the damn chip
This also applies to the motherboard, its VRMs, and the pll voltages, doesn't it? Had my CPU for over 2 years. Still runs fine.
you just don't need 1.5vcore
You just don't need to overclock, do you?
The voltages on the pll for this particular board are tested SAFE values with extra voltage room to spare by me and plenty of other am3/+ overclockers with this line of boards
No. The bios settings for voltages are the same across all of the gigabyte boards. Each specific bios does not have different values deemed "safe".
If the temps are reasonable and the system is tested stable it's not a big fucking deal
Which is EXACTLY proving my point of starting low, and going higher gradually, and not just throwing it up high.
Ever heard of Electromigration.? Just because it's rated to run 1.55v doesn't mean it should
1.55 is tested safe voltage before degradation of the CPU. Although ANY overclocking at all will degrade life, so your point really isn't valid.
I mentioned the board in particular not in general
No, you did not mention HIS board in particular. But all 990 boards in general. You do not know what his INDIVIDUAL board is capable of. Just like CPUs, not all motherboards overclock/overvolt the same.
take the stick out of your ass
Learn what you're talking about. Don't tell people to up their voltages to ANY point that you don't know how their particular case/hardware/cooling set-up can handle. That's a rookie mistake.
To the OP, this thread will have all kinds of info for this particular board
The first comment on that page you posted.
"NB/PCIE/PLL is the 1.8v at stock iirc that is what stabilizes your FSB i have run it up pretty high but it does not help much past stock"
So why should he risk overvolting that blindly, if it doesnt even help stability that much? Again. Bad idea.
