Hey guys. I'm looking to overclock my CPU and my GPU. I have never overclocked before, and I think it's time to push my system a little bit harder to ramp up my performance as much as possible while keeping stable. Here's what I'm running in my system currently. I'm not overly sure what my components are totally capable of and I want to find out! And I would assume that upping the clock speed on the processor (stock @3.8Ghz) would help the GPU out as well. I need to take in as much information as possible.
Step 1: Download prime95 and a program to monitor your temps like coretemp.
Step 2: boot into your bios and raise your core multiplier until your clockspeed is about 200mhz faster.
Step 3: boot into your OS and run prime 95. if you don't get any errors or crashes, go back into the bios and raise the multiplier some more.
Step 4: When you eventually get an error or crash while running prime95, go into your bios and raise the voltage slightly. Run prime95 again, this time monitoring your temps. Make sure your temps are under the max safe temp for your CPU. (about 65 degrees)
If you continue to get crashes, and your CPU is not nearing 65, go back to the bios and raise your voltage some more. If your temps are acceptable and you are not crashing, repeat steps 2-4. When you near your max safe temp you are done. If you are getting errors no matter what you do, go back into your bios and lower your multiplier until you are no longer getting errors.
Awesome! Exactly what I was asking for. Now, if you or anyone has ever overclocked this processor, Please let me know how it went and what I should look out for!
That's really all you have to look out for, temps and errors. Those are independent of processor type so those are your definite limits, regardless of cpu.
The one thing you do need to keep in mind though is that if you're looking at clock speeds that other people are getting, you have to take it with a grain of salt. The silicon lottery may favor them, or favor you, so you could be getting worse or better results depending on your specific cpu. That's why you have to take the steps incrementally because you don't know how your cpu will respond specifically. Don't get me wrong, they're good numbers to compare to, to see how you're doing, but you can't take them as truth for your situation.
