First time CPU overclock (4770k)
Hey guys. Today I started attempting a first time OC with m 4770k. I've been adjusting things and working with stable clocks all morning. I managed to hit 4.2Ghz at 1.140 volts with the system being very stable, so I decided to up my OC a little. I'm currently sitting at 4.5Ghz / 1.220 volts. Anything lower than 1.220 seems to cause instability. I tried 1.195, and 1.200 with the first failing to boot, and the second failing the stress test. 4.5Ghz is exactly where I'd like to be, however I'm wondering if this seems okay/average to you guys. I've seen people squeeze 4.6Ghz out of very similar voltages, but I know every CPU isn't created equally.
My temps are ~28-30 degrees C while idle, and 65-72 degrees C while the CPU is under 100% load. AIDA64 has been running for roughly 20 minutes now and this seems to be about as hot as it's going to get (knock on wood). I do plan on running the test for several hours regardless as I know it's recommended to do so.
Air Cooling: Hyper Evo 212
CPU: 4770k (of course!)
Motherboard: MSI Z87-G45
RAM: G.skill Sniper @ 1600Mhz still running defaults w/ OC
I'm not entirely sure you if need that information, but it's just for reference.Thanks!
Anyone willing to give me a hand with this? :]
Edit (days later): I set the voltage to 1.225 and ran AIDA64 for an hour and 30 minutes without any hiccups. I also continued to game throughout the night without any crashes or system lock-ups. However, I'm still wondering if these temperatures / voltages are safe to run at for extended periods of time.
I realize some degradation comes with any raised voltage, but how much time am I really cutting from my CPU's life-span with these temps? Thanks again for any help!
I have seen others running 4.5GHz overclocks with a voltage of well over 1.300 on a 4770k.
Try increase voltage and stresstest again until you find it stable enough.
SHUT THE CRAP UP X86 LOSERS! (JK) POWERPC EATS X86 FOR DINNER (SRUSLY)
