You rang? ![]()
Ok, U.K, this will be mostly new parts. I picked together this for my nephew about a year ago. The RX580 is fine, not the best but definitely āgame-ableā.
Note that this is my recommended pick with a little extra quality. It costs a bit more than you wished for, but should give you a decent experience despite the parts now starting to reach the 5 year mark. As always, the idea is to make you consider what just going that small, extra mile can do for you. Completely fine if you disagree or feel you cannot afford it. AM4 is probably the best way here, but a case could be made for a 12400 system, too.
| Type | Item | Price |
| CPU | AMD Ryzen 7 5700X | £149.99 |
| CPU Cooler | ARCTIC Freezer 7 X CPU Cooler | £21.34 |
| Motherboard | MSI B550M PRO-VDH WIFI | £99.00 |
| Memory | Kingston FURY Beast 2x16 GB DDR4-3200 CL16 | £42.99 |
| Storage | Kingston Fury Renegade 1 TB M.2-2280 PCIe 4.0 | £70.98 |
| Case | Antec AX61 ELITE | £38.90 |
| Power Supply | Thermaltake Toughpower GX2 600W 80+ Gold | £63.70 |
| Total | £486.90 |
Better motherboard with wifi + bluetooth for £30 extra, twice the amount of RAM for like £10 more, much better boot drive for £20 more, and the PSU might be a tad overkill but is 600W Gold+ for another £10 over budget.
All in all, spending ~25%-30% more for twice the performance isnāt bad. But your money, budget and experience. ![]()
