Was wondering if this build is any good. Please give me your thoughts.
http://pcpartpicker.com/p/CQcp
could you guys also let me know some good gaming monitors for $100-$150 thanks
I think the only thing you should do is maybe bump up the power supply to 750W just for a litle extra room, and also for if you want to upgrade later.
Looks good, yeah. Just bump up your PSU if you plan on lots of future expansions.
Maybe a better case, but that's up to personal preference.
What kind of case would you suggest?
I would recomend the NZXT TEmpest 410 Elite, or the Bitfenix Shinobi (with or without the window). For A first time builder I would not recpmend the Storm Scout, I used it myself for my first build and it was very confusing hooking up all the fans with molex and non-molex, and small things. If you really wantit go a head but I would still recomend the cases I said before more.
Also the speed of that memory is not compatible with your motherboard, with will cause no problems it will automatically be down-clocked, but your not getting what your paying for. I would recommend that same memory of G Skill Ripjaws, but clocked lower, just be sure the clock speed is below 2100MhZ.
is this better http://pcpartpicker.com/p/CSPP
Go with 1866. It's the fastest you can support with that build.
thank you guys very much
If you can aford it I would upgrade the hard drive to a WD Caviar black instead of the Blue.
whats difference between two?
The caviar black has more input output operations per second than the blue
