Storage - WD BLACK 1TB x2 and Samsung 840 Evo 120GB x2 and am looking at a SSD cache drive.
GPU - Really want to go SLI in this build so not really sure at the moment.
PSU - Corsair AX860i
Fans - Changing the two stock fans on the H110 to corsair Sp fans and going to include some more Corsair AF Series fans within the case 140mm and 120mm.
Budget. How much are you willing to spend? Depends on how much money i pull together after Christmas so all options open.
Do you need or already have peripherals? (this can add to costs) Already equipped with peripherals, only thing i may consider doing is upgrading my monitor.
Do you overclock or want to get into overclocking? I would really like to experience and try overclocking as usually i would just stick to stock stats of the item and that does just seem a tad boring.
Do you plan on going for custom water cooling now, or in the future? The idea of water cooling really intrigues me and i would love to try it, however it also frightens me due to the possibility of things going horribly wrong and damaging my new components which cost allot of money.
OS. Do you need a new one? I am sorted for an OS as i have windows 8.1
Do you render movies or Photoshop pictures? I am a graphic design student so i will be using and editing within Photoshop allot, i am also going to be experimenting with Cinema 4D and other software. I also enjoy video editing once every now and then.
What kind of games do you like to play? I like to keep my options open and don't like to stick to one kind of genre so i would say everything and anything.
What resolution will you be playing at? //or would like to play at. I am currently playing at 1920 x 1080 but i would like and am considering on upgrading to 2560 x 1440.
Thank for reading! This is going to be a major step up from my current PC so would really like some feedback.
I think you are just adding the most expensive parts for the sake of it and not really thinking about it.
if you have a $2000 like I suspect:
PCPartPicker part list: http://pcpartpicker.com/p/27B23 Price breakdown by merchant: http://pcpartpicker.com/p/27B23/by_merchant/ Benchmarks: http://pcpartpicker.com/p/27B23/benchmarks/
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor ($299.99 @ Newegg) CPU Cooler: Phanteks PH-TC14PE_BK 78.1 CFM CPU Cooler ($74.99 @ Newegg) Motherboard: Asus SABERTOOTH Z87 ATX LGA1150 Motherboard ($234.99 @ Amazon) Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-2133 Memory ($104.99 @ Amazon) Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-2133 Memory ($104.99 @ Amazon) Storage: A-Data Premier Pro SP900 256GB 2.5" Solid State Disk ($159.99 @ Amazon) Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($84.79 @ Amazon) Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($84.79 @ Amazon) Video Card: Gigabyte GeForce GTX 780 3GB Video Card ($509.99 @ Newegg) Case: Fractal Design Define R4 w/Window (Titanium Grey) ATX Mid Tower Case ($134.98 @ Newegg) Power Supply: SeaSonic X Series 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($181.98 @ Newegg) Total: $1976.47 (Prices include shipping, taxes, and discounts when available.) (Generated by PCPartPicker 2013-11-24 07:34 EST-0500)
Why:
+ 5 year warranty on Sabertooth Mobo's
+16gb ram to increase performance when rendering and compiling.
+single 780 - can sli in future for great performance at 2560x1440p
+Cheaper but equally good PSU, from a solid brand.
+Single ssd to minimize *lost space*
By lost space I mean:
The space left over that is too small for some files, over 2 drives this will be greater than over 1, say you had 1 gb on one drive and 3 on the other, a game was 4gb - been there had the issue before.
+better performing cooler, quieter - expect 50C~ with a hefty OC (I have my [email protected])
*Case is personal choice but by going for an 800D i believe that is just wasting money, I think you could better spend your funds elsewhere. (as seen in the build above)
I'd go single GPU if your buying outright,its normally better for the money, has less issues regarding drivers, stability and support with the added bonus you can always add a second card later, improving speed far more than going from 2 to 3 or even 4 way SLI\Crossfire would. Gpu choice is also really limited to Nvidia if your planning on doing a lot of work with adobe applications due to far better CUDA than OpenCL support.
The fractal design define r4 is smaller than the 800D, will mount 2x140mm rads still and happily fit your build and cable manages nicely. I use a H90 mounted as a rear exhuast and that cools my i7 4770k really well, never even gets to full fanspeed and stock clocks thus is fairly quiet, and never gets up to 70 degress C when overclocked. I have one and only 2 downsides is not very firm cable attachment to inbuilt fan controller and short case feet, other than that its been great, good build quality, very quiet, cools well (even with top and side blanks in like I have), so highly recommended.
I'd get a 2+ terrabyte 7200rpm drive rather than a pair of drives unless your going raid 1.0, really raid 0 HDD's isn't going to help much if you have decent ram space and a SSD. If you want more space than 2tb, I'd go 3+ 2tb drives in raid 5, this insures you against a drive failing while giving increased speed and storage and is supported by most modern motherboards right out of the box.
Thanks for the feedback, and yes it is quite expensive however the only reason i considered parts like this was because i wanted to make it is future proof and i thought this would kind of do that. I choose the corsair h110 because i have a CPU cooler like the one above that you listed and personally its good performance but i just don't like how big they are and how they look. Your right about the case though it is very expensive however i don't mind "wasting money" on it as i really like the look of it and how much room there is and surly the room and size aspect of this case will also help for future proofing. When i started thinking of parts for this build i was also thinking of a color scheme, so the asus motherboard and the power supply fit right in for a red and black scheme. I think it is a very good idea for changing the memory as dominator platinum is stupidly expensive so i think im going to change that, and having one ssd is probably better than two as well. I am most likely not going upgrading for a long time, so i kinda need it as future proofed as possible really. What are your thoughts considering i wish to go with a color scheme (red and black) and wanting it to be future proof?
Thanks for the feedback! That's and interesting idea regarding raid 5, i think that is a good idea to consider. I notice allot of people use the fractal cases for there build and they give really good reviews on it however personally i really like the 800d due to the space and look of it but like Zynchronise said the case is a personal choice. Another reason why i considered going with the 800d is because i want to future proof my system and i thought the space may really come in handy in the future, and regarding the graphics card i was most likely always going to go with nvidia guess that's just a personal thing to though. Do you have any ideas that may help to future proof this build? would love some help.
You can get 2 double slot graphics cards and a couple of other single slot cards on the saber tooth in the define r4 no problem, having more room in the case actually doesn't help at all as you have a fixed number of expansion slots till you go to a XL mobo, which I can't see you doing unless you want 4 GTX graphics cards (many quattro's are single slot), but there is a define r2 XL is you want to go that way. Regarding a rad, the H90 has served me well so far, and cost a lot less than a H110. However its biggest asset over a twin fan rad is you can keep the top and side panel blanks in, which decreases case noise. Its also quieter than a H80i. For future proofing, get a 800+ watt psu so you can run 2 graphics cards, a decent case (anything from a 200r up works) and avoid filling all your slots, so 2x8gb ram is better than 4x4gb because you can increase to 32gb total later on, same goes for PCIe and Sata3 slots.
Not wanting to spam here to much but if your willing to spend a few extra dollars you can do a much faster build by going to 6 core i7's on 2011 socketed mobo's.
Here is a example X79 2011 socket build, it'll cost $2200 but is 50% faster in the cpu, has 8 ram slots and 2 PCIe slots at 16x speed, ideal for SLI or Crossfire. I also used the H110 in the Define R4, as this CPU will sure make some heat overclocked and this is a money in option, so cool, quiet running is mandatory. Also ignore the compatiblity warning, if you look it up its and issue with a select few bios versions on some motherboards and isn't applicable in this case, will run fine you of the box. You'll still need wifi and fans, but these are preference Items, personally I'd get 2 noctua force 140mm PWM and stick them on the H110, then use its fans in the bottom while the included case fans run at the front off the included fan controller. Link: http://pcpartpicker.com/p/27Clj
Thanks for the feedback that is a very good idea about the ram i think i might do that and i think i might do some more research into the corsair CPU coolers, some interesting stuff to know thanks, what would you suggest about the color scheme because i think i want to go with a red and black color scheme but not sure any ideas? and im going to look into the define r2 cases now.
I usually recommend getting the best single-GPU solution you can buy. It's a better experience in the end. Also, you can save some money usually by buying a 2TB Caviar black and a 250GB 840 EVO SSD. Sheepinacart's 780ti build is quite nice.
