First PC Build, Advice and Help Appreciated
'm 16, trying to build first pc, I've re-earned some money and I'm ready to assemble my own pc. I wanna keep it around 700-800ish so i can buy a fancy monitor for cs. Coming from a low end laptop that couldn't run jack sh*t, so I'm very excited. Took some parts from Logans video, changed out a few, just want other peoples advice. I'm not gonna post links because that's beyond confusing and too many tabs for you guys, so just part names:
CPU: AMD FX6350 3.9Ghz
COOLER: Corsair H100i - liquid 240mm
MOBO: i havent decided, want to keep it under 100, not sure yet (prefer an all black one for matching parts xP)
RAM: ADAT XPG V1.0 8GB DDR31600
GPU: XFX R9 280X BLACK OC EDITON <- lifetime warranty
PSU: EVGA SuperNOVA NEX750 B (modular)
HARD DRIVE: Kingston HyperX 3K SH103S3 120GB ( It'll be plenty don't worry, on 3 games, i don't use much.)
CASE: Corsair 300R windowed
already have an optical drive.
ANY ADVICE WELCOME
Heh, I know the feeling.  When I was 16, I bought a used gaming desktop and upgraded it a little bit.  No more playing FPSs at 12fps.
Not bad for a build, but a little unbalanced here and there, and kind of a crap psu(4 +12V rails).  FX-6350 isn't worth the price premium over the FX-6300 as well.  Also, your total will be over 800.  I'm not sure if you want to crossfire later on, so I'll give you a couple builds:
No Crossfire-able, slight OCs should be ok:
http://pcpartpicker.com/p/2gdJA
Crossfire-able, but lower initial performance, no OC until aftermarket HS/F:
http://pcpartpicker.com/p/2gdOD
You might experience some CPU bottlenecking with the crossfire, though.  I'd suggest trying to get an FX-8320 or higher for the crossfire build.
The Gigabyte GA-970A-UD3 is a pretty good AM3+ motherboard, but its a bit over $100.  I use a Gigabyte 990FXA-UD3 for my FX-8350 and its excellent.  The GA-970A-UD3 is essentially the same board, just an older chip set.
I can clock my FX-8350 up to 4.6GHz no problem but after that I start to worry about heat as the VRM heatsink starts getting really hot.  I am sure it will go past 4.6GHz but I dont feel that it's safe with the VRM that hot with it's stock heatsink.  I keep my 8350 @ 4.5Ghz.  So in summary I would say its a slightly above average board for overclocking but nothing like what an Asus ROG board can do or a Sabertooth board.... it is however very nicely priced and it has a nice UEFI dual bios.
