Sadly, I have been avoiding the gpu/asic mining thing, rather investing in crypto as a buy n hold/trade/leverage trade strategy. I want to expand my investment so I got an Asus z170 mobo to match my used 6600k/6500 (whichever I chose to use, the other I will likely sell) and I just got a second gtx 1080 ftw (in snail mail atm).
I am so excited!!! I am going to have a crypto miner in my living room!!! haha
That all said, I have been watching and reading and learning the past few weeks about setup and configuration, os and softwares, etc.
I think what I want is this:
Windows OS and possibly T_Rex for mining software. No nicehash for me after learning the creator was actually a cyber criminal (once a shithead always a shithead I say). So T_Rex or Hive_OS may be better?
I see there is a little configuration in windows to get ready for mining, then the miner software, and thats really it? What about mining pools? I have one guy I like to learn from on YT, Sebs FinTech Channel, and he is using Ethminer or something …
What Mining pool do you use for what crypto?
What crypto should I be mining? Everyone is mining Etherium atm but when that pops 2.0 out, no more mining Eth, so what then?
I seen Raven coin, NANO, Eth, all being popular. I want to know what you do, how you got setup for your first build.
From my calculations, a single gtx 1080 can pay itself off in about 6 months if the price stays where its at right now. Id be making almost 5$ a day with two 1080’s. Thats pretty good for me starting out, I will be adding a third 1080 asap, within those first 6 months. My goal is to help pay off my CC’s fo the first year or two, and then rake in the coins, not profits. I will be holding those coins for long term investment.
Is there anyway I can find what coins can be mined with 1080’s?
I appreciate any help, tips, and especially links to information that will set me on a successful path as a hobbiest crypto miner! Instead of buying a 2000$ purism laptop, me wondering if I shouldnt have bought 4 more 1080’s
but I feel, I want the librem 14 and can add more GPU as they pay themselves off in time?
Cheers!
Only real concern of mine is moisture. Heat and moisture can kill electronic equipment so I will do some reading and expirementing slowly to see if its safe to run outside all winter. It hardly snows here but it gets 30* outside and its usually moist out/rainy.
