I am going to build my first pc I did my homewoork and I know what I want:
CPU:I5 2500k
GPU: 660ti
Motherboard: ASRock z77 pro4
PSU: need help!
SSD: OCZ vertex 4 64 gb
Ram: Corsair Vengeance 8gb (2x4) 1600 mhz
Case: Cooler Master HAF 912
HDD: Don't know yet probebly something later on
So I need help to see if everything is compadible or everything fit and all that the budget was aboute $1000 the PSU I need help with I thought abute the XFX ProSeries 750w is that good or not?
PSU: That 750 from XFX is definitely plenty with a ton of leg room if you wish to add much more power hungry cards in the future and OC your 2500k.
I do not see a heatsink i highly recomend one if you plan to OC that 2500k, a Hyper 212 EVO is a very good budget cooler. THe havik 140 also fits in your case and would be a really wonderful adition to your rig, giving you plenty of cooling for pushing your 2500k.If you do decide to get a aftermarket cooler, get the low profile Vengeance kit , makes clearence issues dissapear.
If you plan to get a 64gb ssd i highly recomend you get a small hard drive to go with it for your games and files, a large portion of your ssd will be gone with just the windows install alone. Add a few newer games that can be over 7+gigs and you will quickly run out of room.
That 660Ti is a proper nice card, can you post what prices your parts cost? Maybe we can help you find better deals.
