Hi everyone! Gonna be doing my first build pretty soon and I’m real excited to be taking my first steps into the awesome world of PC enthusiasm! I’ve been doing research and parts selection for a number of months now. I have most of the components picked out at this point, however there are still a number of things that I’m not sure about and could use some advice/opinion on. First things first though, a bit about my prospective system:
http://pcpartpicker.com/p/299mg
Parts I plan to add after initial build:
PCI-E cards: AverMedia Live Gamer HD, discrete sound card (model undecided), possibly others (more Ethernet ports! :P)
Mechanical drive if storage space runs low (right now looking at Western Digital WD Black)
More fans for better airflow: 3x 140mm (model undecided), 1x 230mm (BitFenix 230Mm Blue Led Case Fan)
This computer would be used mainly for content creation (digital painting in fairly large formats, 3D modeling/sculpting, and eventually video editing and/or online streaming) as well as gaming. Some of the programs I plan to use include Photoshop CS6, autodesk maya, mudbox, and UDK. I have no plans to overclock my system right out the gate, however I would like to have it as an option if I want to attempt overclocking in the future. With all that out of the way, here are my questions/concerns:
Motherboard: I’m a little confused about compatibility with the NZXT case. PcPartPicker says the two are not compatible, but I have seen contradictory claims. While SSI CEB is not a listed form factor supported by the case, I have read elsewhere that it uses the same standoff points as a standard ATX mobo and, while wider, would still fit in the case; which answer would be correct in this instance? My other motherboard concerns fit better in other sections, namely the CPU cooler and RAM, so I’ll put them in there.
----------CPU cooler: not really sure here, though I know I’m looking for a good air cooling unit. From what I’ve seen on the net and in forums my chosen ram seems to be low enough profile for some of the bigger heatsinks that reach into the ram slots, though I’m worried about a bigger heatsink making contact with whatever I put in the first PCI-E slot and causing a short. Any recommendations on an electrically non-conductive something-or-other I could stick between a PCI-E card and the CPU cooler to give me worry-free use of the first PCI-E slot (would the backplate on the Asus DCU II fulfill this purpose)? Can a smaller heatsink still provide good cooling for a slight to moderate overclock (around 3.8-4.2GHz)? Right now I am looking into Phanteks PH-TC14PE as a larger option, smaller options being Noctua NH-U12S and Dark Rock Pro 2 (width is only 225mm w/o middle fan). Also, how likely is it that one of these heavier cooling units will bend my motherboard?
----------Ram: My chosen RAM’s speed is listed as an overclock speed on the P9X79, how confidant can I be that my ram would be stable at the factory default speed of 1866?
Storage: What is the average lifespan of a modern SSD’s in comparison to a mechanical hard drive? How about the failure rate of the Crucial drive listed above compared to another brand/model (say, Samsung 840 EVO 1tb)? Does putting them in RAID do anything to increase or decrease failure probability of the individual drives? Finally -and more out of curiosity than anything else- would SSD caching provide any improvement on a system that exclusively uses SSD storage?
PSU: I plugged the specs for my planned initial build as well as specs for what I plan to add in my future system into http://extreme.outervision.com/psucalculatorlite.jsp (I did not include any CPU overclock numbers), the calculator tended to give results from around 900-1100 recommended wattage depending on whether or not I included parts from the expanded build. I really have no way of knowing how accurate these calculations are, so I figured I’d get a second opinion. Is the Antec PSU overpowered, underpowered or in a good range for my build? If it is overpowered, how much farther down can I go in capacity and still have room to add to my system?
Well I think that’s all of it. If I could get all of my questions answered that would be awesome, though I had a lot so it’s understandable if this doesn’t happen. Thanks for taking the time to read through my wall of text… and apologies for the aforementioned wall of text XD
Finally, if you see any obvious bottlenecks/compatibility issues in my proposed build that I overlooked please let me know.
