First build ever
This is my build. Let me know what you think. Also your videos on YouTube are great!
http://pcpartpicker.com/p/3tG7s
go with this gpu you will get slightly better performance for the same price depending on where you live and who you are buying it from, its all up to you though, otherwise the parts look good.
Do you have another drive other than that 120 gb? because believe me it will fill up fast even after installing windows and all the programs you want, you will have around 50 gigs left.
I will be getting a HDD just as soon as I can afford it. Thank you for the reply. I'll have to do some research on that r9 270.
