Firmware - Cisco Intel X710-DA & X710-DA2
I went through a lot of headaches getting these firmware versions and I thought I would share and possibly help someone else in need of these. Inside the zip is a read me file containing instructions. I don’t know how else I should post these firmware files but I figured I share here. Happy updating!!!
SHA1 Hash:
cdb1e58de3de5db8eae074171be07e2e59a325d4 *Cisco X710-DA Firmwares.zip
Cisco X710-DA Firmwares.zip (5.9 MB)
Any chance you have even more up to date ones, hate asking but recent ran into this and its a PITA
Those are the latest that I could find. I basically had to strip them out of some OS update iso/images I found and reverse engineer their firmware file encryption method.
@camix any chance you can remember the steps that you used to extract those files from the firmware iso? I’ve got the latest UCS firmware files but no doubt as you noticed the default format seems to be encoded/compressed/encrypted somehow and I’m not sure how their tool reverses that. Thanks in advance.
Can you send me or post a link to the ISO? I can look to see if it’s doable with your version.
