Finishing my PC build
So here is my PC build:http://pcpartpicker.com/p/2ZQAk
I already own the PSU,Case,Fans,ram, and thermal paste. Is it any good? And on a sidenote, is the PSU compatible with everything? Im worried about the PSU might not be able to connect to the GPU.
The case is eh.  I would really get a new one.  It is too cramped in there, and offers no cable management.  I personally would get a modular or semi-modular PSU.  Like the CX500M.
gotta say to you. If you are going AMD FX CPU, don't pick a mATX mobo, they are pure bs... a minimum for a AM3+ mobo would be a ASUS M5A97 R2.0, or something with at least 4+2 phase power desing and a cooler on it
I agree with both of the above, AM3+ mATX boards are pretty pathetic. ASUS makes great AM3+ boards (I have owned 3 of them. they have great UEFIs and overclock like champions). the GTX 760 says it needs a 500W minimum so the 430W wont cut it (760 has a 6 pin and an 8 pin PCIE connector. your PSU only has a 6 pin. dont skimp on your PSU Corsair and nzxt make solid products, I would add more but those are the only ones I have experience with.
Also if you can spare the cash an SSD is a beautiful thing to run your OS and your core apps, blazing fast read/write speeds = less time waiting for things to load/install
