Hey guys
I am going to finish my build and want some help.
First of all I need a new case. I need one that has good amount of room for HDDs and SSDs. The price I would like is up to £100.
Next is a new graphics card, I was thinking of either a GTX 760 or 770. I will be playing games on a single 1080p monitor. Is the extra performance good for the extra bit of money?
Also I will need a new PSU to go with the graphics card.
Thanks in advance :)
For a case you can get a CM HAF X , its a really nice case.
As for the GPU i would suggest a 770 so that you will be future proof and it definitely will provide more performance than the 760.
For a PSU if you need a very high power supply get a cooler master v1000 if a 700 just get one from a good brand like cooler master or corsair make sure its at least 80+ bronze certified.
Hope i could help :D
Get a Define R4 for the case, with the GTX 770 and the be quiet! Sytem Power 7 600W PSU (80+ silver)
http://pcpartpicker.com/p/1jSCh
Fractal's Define R4 is an amazing case. It has room for 8 drive bays and 2 additional SSD-mounting spots. It is also one of the quietest cases you can buy and for 80$ its a real bargain as well.
The MSI is the quietest 760 you can buy at the moment and quiet fast too.
I would not go 770 for 1080p - you don't need it and its nearly 150$ premium. Rather save the money now and upgrade in a year or two. You will have a fast enough card right now and in 2 years you will have a card that is way faster than the 770 you could buy today.
BTW
I don't usually recommend power supplies, because I get bashed for picking premium ones, which most people think are to expensive (I disagree):
- Seasonic SS-520FL (520W, 80+ Platinum, Fanless)
- Corsair AX760(i) (760W, 80+ Platinum, Semi-Passive)
Prices for these parts are well over 100$...
