Im looking for a 7970ghz edition to finish off my pc build, which has been lacking a gpu since august, I have everything I need and it will run a 7970, I have enough power (750w) it wont bottleneck with the core (3570k @ 4.2ghz) and I have way more than enough room in the case (like 25 inches). Im looking for a 7970ghz edition that I can get in england for less than £340 Preferably with a Black pcb and/or or a backplate.
I was thinking of getting this: http://www.overclockers.co.uk/showproduct.php?prodid=GX-073-HS&groupid=701&catid=56&subcat=938 But as you can see it has a blue pcb and no backplate, and Im quite fussy considering every time I look in my case ill see that messy blue pcb, even though my motherboard is black and blue (p8z77-v) it probably looks..........meh. Thanks for any links guys! I appreciate it, I finally decided to get the card after months of waiting because AMD says that their releasing the 8000 series late in 2013, and I cant be bothered to wait that long. Thanks again!
