Finalizing my build. Buying Parts Tonight!
http://pcpartpicker.com/user/colin98/saved/3lUK
I will be ordering everything tonight to build my pc. I want to make sure I will have no problems. I have a couple concerns.
1. Will the 430w PSU be enough to run this without problems?
2.Will this PSU have all the necessary connectors run everything?
3.The Motherboard will run the cpu prior to a bios update?
4.Will everything will fit in the case?
5.All the parts work together well and have no compatibility issues?
6.I have everything needed listed to run the pc.
Lastly i will be running this pc on a wireless connection so I need a suggestion for a wifi card. i'm not sure what info you need to make a good suggestion but my router is a ActionTek Mi424wr Rev e and when I run a wireless speed test with my iMac being about 5 feed from the router I get this.
Thanks for any advice whoever gives.
I changed around a few parts - http://pcpartpicker.com/p/2xv6W
I selected a different motherboard with better reviews.  The selection for AM3+ MicroATX motherboards is pretty slim.
I changed out the video card to one that's a bit cheaper, but should be near the same performance, especially if you overclock it a bit.
I changed out the memory with faster, cheaper RAM.
I changed out the monitor to a different Asus model that is still the same size, while still retaining the IPS.
1. 430 watts should be enough for this build, but there's no room to upgrade to an 8 core processor or to a high end graphics card, so you may need to upgrade the PSU as well if you decide you want one of those.
2. Yes
3. I think this motherboard should run the processor without a BIOS update.  I believe that only applies if you are running an 8 core, like the 8320 or 8350, but I could be wrong.
4. Yes
5. Yes, everything should work together just fine.
6. The only things missing are an optical drive and an operating system, but if you already have Windows, you can install it from a USB flash drive.
You could get a MUCH better/upgradeable system if you have room for a full size ATX motherboard and a mid tower case.  If you do, I would suggest getting these parts instead:
http://pcpartpicker.com/p/2xvhz
Thanks for the help. If I were to go full size ATX I would have to do something more like this:
http://pcpartpicker.com/user/colin98/saved/3n2m
I took off the aftermarket cooler and changed the mobo to a 970 model since I don't think I need it since will not be over clocking really.
Also if I don't plan on upgrading for a while(atleast 2-3 years) and when I do I will be upgrading most of the parts should I just go with the Matx build to save some money now? Or is the ATX build still better disregarding upgradability?
I would be WAY more comfortable with that M5A97 R2.0 motherboard than with the microATX board.  It's got more reviews and has better support for the 6300.  It may require a BIOS update, but you'd be better off in the long run.
The case also has better cable management, a cutout for an aftermarket cooler, and more room inside for better airflow.  Even if you don't overclock, the EVO 212 would probably be quieter and is much more efficient than the stock cooler.
So, yes, even if you don't necessarily need the upgradeability of the 990FX, I'd still go for the ATX build.
OK thanks for all the help. I will go with the ATX build as you suggest. I can't wait to have it up and running.
