Fedora update from 42 to 43 issue
Hello, I am trying to update Fedora to 43 but I am getting this error when I use the Software App tool included in Fedora:
Error running transaction: file /usr/lib/wine/i386-windows/urlmon.dll conflicts between attempted installs of wine-core-10.20-2.fc43.i686 and wine-core-10.20-2.fc43.x86_64
file /usr/lib/wine/i386-windows/windows.devices.bluetooth.dll conflicts between attempted installs of wine-core-10.20-2.fc43.i686 and wine-core-10.20-2.fc43.x86_64
file /usr/lib/wine/i386-windows/wined3d.dll conflicts between attempted installs of wine-core-10.20-2.fc43.i686 and wine-core-10.20-2.fc43.x86_64
I’ve searched on Internet and it seems related to a sort of bug and the best possible solution is to uninstall Wine, update Fedora, reinstall Wine. However, if I do sudo dnf remove wine on terminal, it says: No packages to remove for argument Wine.
I have Wine, as well as Proton, etc., how do I completely uninstall it, clean any residual, and then update my Fedora?
Also, is there anything else should I be aware/prepared of about the update?
Had the same problem when uprgading :fedora: 42 to :fedora: 43. Solved it by running
sudo dnf remove 'wine*'
There is wine.i686 & wine.x86_64 (+ all the other packages like wine-core)
Thank you so much, I have managed to remove Wine and so updating Fedora to 43 successfully!
