Looks like I’m getting a segfault on the new B3 version. B2 was working pretty well, few crashes every now and then. B3 builds just fine with gcc version 8.3.0 (Debian 8.3.0-6).
Command is : ./looking-glass-client -p 5902 -a -r
Text of crash is:
77471404899 [I] main.c:2272 | main | Looking Glass (B3-rc1-0-g185c7764ba)
77471404961 [I] main.c:2273 | main | Locking Method: Atomic
77471602862 [I] ivshmem.c:127 | ivshmemOpenDev | KVMFR Device : /dev/shm/looking-glass
77471700113 [I] egl.c:225 | egl_initialize | Double buffering is off
77471700135 [I] main.c:1646 | try_renderer | Using Renderer: EGL
77471703499 [I] x11.c:104 | x11Init | X11 XInput 2.3 in use
77471730059 [I] egl.c:505 | egl_render_startup | use native: false
77471758947 [I] egl.c:565 | egl_render_startup | Multisampling enabled, max samples: 4
77471770052 [I] egl.c:616 | egl_render_startup | Single buffer mode
77471807512 [I] egl.c:632 | egl_render_startup | EGL : 1.5
77471807538 [I] egl.c:633 | egl_render_startup | Vendor : NVIDIA Corporation
77471807548 [I] egl.c:634 | egl_render_startup | Renderer : GeForce GTX 750 Ti/PCIe/SSE2
77471807554 [I] egl.c:635 | egl_render_startup | Version : OpenGL ES 3.2 NVIDIA 460.32.03
77471807562 [I] egl.c:636 | egl_render_startup | EGL APIs : OpenGL_ES OpenGL
77471807567 [I] egl.c:637 | egl_render_startup | Extensions: EGL_EXT_buffer_age EGL_EXT_client_sync EGL_EXT_create_context_robustness EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_MESA_image_dma_buf_export EGL_EXT_output_base EGL_EXT_stream_acquire_mode EGL_EXT_sync_reuse EGL_IMG_context_priority EGL_KHR_config_attribs EGL_KHR_create_context_no_error EGL_KHR_context_flush_control EGL_KHR_create_context EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_partial_update EGL_KHR_swap_buffers_with_damage EGL_KHR_no_config_context EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_reusable_sync EGL_KHR_stream EGL_KHR_stream_attrib EGL_KHR_stream_consumer_gltexture EGL_KHR_stream_cross_process_fd EGL_KHR_stream_fifo EGL_KHR_stream_producer_eglsurface EGL_KHR_surfaceless_context EGL_KHR_wait_sync EGL_NV_nvrm_fence_sync EGL_NV_post_sub_buffer EGL_NV_quadruple_buffer EGL_NV_stream_consumer_eglimage EGL_NV_stream_cross_display EGL_NV_stream_cross_object EGL_NV_stream_cross_process EGL_NV_stream_cross_system EGL_NV_stream_dma EGL_NV_stream_flush EGL_NV_stream_metadata EGL_NV_stream_remote EGL_NV_stream_reset EGL_NV_stream_socket EGL_NV_stream_socket_inet EGL_NV_stream_socket_unix EGL_NV_stream_sync EGL_NV_stream_fifo_next EGL_NV_stream_fifo_synchronous EGL_NV_stream_consumer_gltexture_yuv EGL_NV_stream_attrib EGL_NV_stream_origin EGL_NV_system_time EGL_NV_output_drm_flip_event EGL_NV_triple_buffer EGL_WL_bind_wayland_display EGL_WL_wayland_eglstream
77471807585 [W] egl.c:650 | egl_render_startup | NVIDIA driver detected, ignoring broken DMA support
77471821786 [E] crash.c:180 | crit_err_hdlr | ==== FATAL CRASH (B3-rc1-0-g185c7764ba) ====
77471821842 [E] crash.c:181 | crit_err_hdlr | signal 11 (Segmentation fault), address is 0x70
77471822753 [E] crash.c:204 | crit_err_hdlr | [trace]: (0) x11.c:0 (x11EventFilter)
77471822812 [E] crash.c:209 | crit_err_hdlr | [trace]: (1) ./looking-glass-client(eventFilter+0x25) [0x3417b8d99e4]
77471822824 [E] crash.c:209 | crit_err_hdlr | [trace]: (2) /usr/lib/x86_64-linux-gnu/libSDL2-2.0.so.0(+0x38d00) [0x6cc178248d00]
77471822834 [E] crash.c:209 | crit_err_hdlr | [trace]: (3) /usr/lib/x86_64-linux-gnu/libSDL2-2.0.so.0(+0x39466) [0x6cc178249466]
77471822843 [E] crash.c:209 | crit_err_hdlr | [trace]: (4) /usr/lib/x86_64-linux-gnu/libSDL2-2.0.so.0(+0xca360) [0x6cc1782da360]
77471822852 [E] crash.c:209 | crit_err_hdlr | [trace]: (5) /usr/lib/x86_64-linux-gnu/libSDL2-2.0.so.0(+0xcb7ac) [0x6cc1782db7ac]
77471822870 [E] crash.c:209 | crit_err_hdlr | [trace]: (6) /usr/lib/x86_64-linux-gnu/libSDL2-2.0.so.0(+0x38b97) [0x6cc178248b97]
77471822882 [E] crash.c:209 | crit_err_hdlr | [trace]: (7) /usr/lib/x86_64-linux-gnu/libSDL2-2.0.so.0(+0x38c15) [0x6cc178248c15]
77471822910 [E] crash.c:204 | crit_err_hdlr | [trace]: (8) main.c:0 (lg_run)
77471822938 [E] crash.c:209 | crit_err_hdlr | [trace]: (9) ./looking-glass-client(main+0x868) [0x3417b8e1059]
77471822953 [E] crash.c:209 | crit_err_hdlr | [trace]: (10) /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xeb) [0x6cc17749409b]
77471822980 [E] crash.c:209 | crit_err_hdlr | [trace]: (11) ./looking-glass-client(_start+0x2a) [0x3417b8d335a]
Segmentation fault (core dumped)
Stack trace (can’t include links apparently)
execve("./looking-glass-client", ["./looking-glass-client", "-p", "5902", "-a", "-r"], 0x76e39b50d6c0 /* 21 vars */) = 0
brk(NULL) = 0x69d6f0e3c84
access("/etc/ld.so.preload", R_OK) = 0
openat(AT_FDCWD, "/etc/ld.so.preload", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=0, ...}) = 0
close(3) = 0
openat(AT_FDCWD, "/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=150225, ...}) = 0
mmap(NULL, 150225, PROT_READ, MAP_PRIVATE, 3, 0) = 0x6b90b21f8000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libSDL2-2.0.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P\v\2\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1290408, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6b90b2254000
mmap(NULL, 1315848, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b20b0000
mmap(0x6b90b20d0000, 819200, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x20000) = 0x6b90b20d0000
mmap(0x6b90b2198000, 299008, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe8000) = 0x6b90b2198000
mmap(0x6b90b21e1000, 45056, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x130000) = 0x6b90b21e1000
mmap(0x6b90b21ec000, 21512, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x6b90b21ec000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libgmp.so.10", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\306\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=533280, ...}) = 0
mmap(NULL, 535424, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b2028000
mprotect(0x6b90b2033000, 483328, PROT_NONE) = 0
mmap(0x6b90b2033000, 385024, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xb000) = 0x6b90b2033000
mmap(0x6b90b2091000, 94208, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x69000) = 0x6b90b2091000
mmap(0x6b90b20a9000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x80000) = 0x6b90b20a9000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000\21\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=14592, ...}) = 0
mmap(NULL, 16656, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b2020000
mmap(0x6b90b2021000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x6b90b2021000
mmap(0x6b90b2022000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b2022000
mmap(0x6b90b2023000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b2023000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/librt.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260#\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=35808, ...}) = 0
mmap(NULL, 39904, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b2010000
mmap(0x6b90b2012000, 16384, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b2012000
mmap(0x6b90b2016000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x6b90b2016000
mmap(0x6b90b2018000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x6b90b2018000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libm.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0p\322\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1579448, ...}) = 0
mmap(NULL, 1581384, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b1e88000
mmap(0x6b90b1e95000, 651264, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd000) = 0x6b90b1e95000
mmap(0x6b90b1f34000, 872448, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xac000) = 0x6b90b1f34000
mmap(0x6b90b2009000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x180000) = 0x6b90b2009000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libX11.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P\351\1\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1310216, ...}) = 0
mmap(NULL, 1314168, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b1d40000
mprotect(0x6b90b1d5c000, 1175552, PROT_NONE) = 0
mmap(0x6b90b1d5c000, 565248, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1c000) = 0x6b90b1d5c000
mmap(0x6b90b1de6000, 606208, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa6000) = 0x6b90b1de6000
mmap(0x6b90b1e7b000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x13a000) = 0x6b90b1e7b000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libXi.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\320!\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=63976, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6b90b2252000
mmap(NULL, 2159272, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b1b30000
mprotect(0x6b90b1b3f000, 2093056, PROT_NONE) = 0
mmap(0x6b90b1d3e000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0x6b90b1d3e000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libXfixes.so.3", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220\25\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=22656, ...}) = 0
mmap(NULL, 2117912, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b1928000
mprotect(0x6b90b192d000, 2093056, PROT_NONE) = 0
mmap(0x6b90b1b2c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x6b90b1b2c000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libXss.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\21\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=14528, ...}) = 0
mmap(NULL, 16712, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b1920000
mmap(0x6b90b1921000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x6b90b1921000
mmap(0x6b90b1922000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b1922000
mmap(0x6b90b1923000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b1923000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libnettle.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`\231\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=224472, ...}) = 0
mmap(NULL, 226472, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b18e8000
mmap(0x6b90b18f1000, 118784, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9000) = 0x6b90b18f1000
mmap(0x6b90b190e000, 61440, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x26000) = 0x6b90b190e000
mmap(0x6b90b191d000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x34000) = 0x6b90b191d000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libhogweed.so.4", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \216\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=229192, ...}) = 0
mmap(NULL, 231192, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b18a8000
mprotect(0x6b90b18b0000, 192512, PROT_NONE) = 0
mmap(0x6b90b18b0000, 65536, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8000) = 0x6b90b18b0000
mmap(0x6b90b18c0000, 122880, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x18000) = 0x6b90b18c0000
mmap(0x6b90b18df000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x36000) = 0x6b90b18df000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libEGL.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P4\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=80448, ...}) = 0
mmap(NULL, 83856, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b1890000
mmap(0x6b90b1893000, 45056, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x6b90b1893000
mmap(0x6b90b189e000, 20480, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0x6b90b189e000
mmap(0x6b90b18a3000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x12000) = 0x6b90b18a3000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libwayland-egl.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`\20\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=14216, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6b90b2220000
mmap(NULL, 16440, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b1888000
mmap(0x6b90b1889000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x6b90b1889000
mmap(0x6b90b188a000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b188a000
mmap(0x6b90b188b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b188b000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libwayland-client.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`T\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=64840, ...}) = 0
mmap(NULL, 66920, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b1870000
mmap(0x6b90b1875000, 24576, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0x6b90b1875000
mmap(0x6b90b187b000, 12288, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xb000) = 0x6b90b187b000
mmap(0x6b90b187e000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd000) = 0x6b90b187e000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libbfd-2.31.1-system.so", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0p-\4\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1300808, ...}) = 0
mmap(NULL, 1321152, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b1728000
mmap(0x6b90b1769000, 712704, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x41000) = 0x6b90b1769000
mmap(0x6b90b1817000, 217088, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xef000) = 0x6b90b1817000
mmap(0x6b90b184c000, 110592, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x123000) = 0x6b90b184c000
mmap(0x6b90b1867000, 14528, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x6b90b1867000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@l\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=146968, ...}) = 0
mmap(NULL, 132288, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b1700000
mmap(0x6b90b1706000, 61440, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x6b90b1706000
mmap(0x6b90b1715000, 24576, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x15000) = 0x6b90b1715000
mmap(0x6b90b171b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1a000) = 0x6b90b171b000
mmap(0x6b90b171d000, 13504, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x6b90b171d000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libSDL2_ttf-2.0.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000#\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=31032, ...}) = 0
mmap(NULL, 33208, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b16f0000
mmap(0x6b90b16f2000, 16384, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b16f2000
mmap(0x6b90b16f6000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x6b90b16f6000
mmap(0x6b90b16f7000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x6b90b16f7000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libfontconfig.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20x\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=281592, ...}) = 0
mmap(NULL, 284296, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b16a8000
mmap(0x6b90b16af000, 147456, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x6b90b16af000
mmap(0x6b90b16d3000, 98304, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2b000) = 0x6b90b16d3000
mmap(0x6b90b16eb000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x42000) = 0x6b90b16eb000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libfreetype.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\320\331\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=763816, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6b90b221e000
mmap(NULL, 765968, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b15e8000
mprotect(0x6b90b15f5000, 684032, PROT_NONE) = 0
mmap(0x6b90b15f5000, 512000, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd000) = 0x6b90b15f5000
mmap(0x6b90b1672000, 167936, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8a000) = 0x6b90b1672000
mmap(0x6b90b169c000, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xb3000) = 0x6b90b169c000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libGLU.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20U\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=457424, ...}) = 0
mmap(NULL, 459416, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b1570000
mprotect(0x6b90b1575000, 434176, PROT_NONE) = 0
mmap(0x6b90b1575000, 335872, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0x6b90b1575000
mmap(0x6b90b15c7000, 94208, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x57000) = 0x6b90b15c7000
mmap(0x6b90b15df000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6e000) = 0x6b90b15df000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libGL.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 2\4\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=596296, ...}) = 0
mmap(NULL, 604400, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b14d8000
mprotect(0x6b90b151b000, 217088, PROT_NONE) = 0
mmap(0x6b90b151b000, 126976, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x43000) = 0x6b90b151b000
mmap(0x6b90b153a000, 86016, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x62000) = 0x6b90b153a000
mmap(0x6b90b1550000, 110592, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x77000) = 0x6b90b1550000
mmap(0x6b90b156b000, 2288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x6b90b156b000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260A\2\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1824496, ...}) = 0
mmap(NULL, 1837056, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b1310000
mprotect(0x6b90b1332000, 1658880, PROT_NONE) = 0
mmap(0x6b90b1332000, 1343488, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x22000) = 0x6b90b1332000
mmap(0x6b90b147a000, 311296, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x16a000) = 0x6b90b147a000
mmap(0x6b90b14c7000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1b6000) = 0x6b90b14c7000
mmap(0x6b90b14cd000, 14336, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x6b90b14cd000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libasound.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\374\2\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1046824, ...}) = 0
mmap(NULL, 1049392, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b1208000
mprotect(0x6b90b1235000, 831488, PROT_NONE) = 0
mmap(0x6b90b1235000, 589824, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2d000) = 0x6b90b1235000
mmap(0x6b90b12c5000, 237568, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xbd000) = 0x6b90b12c5000
mmap(0x6b90b1300000, 36864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf7000) = 0x6b90b1300000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libpulse-simple.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 #\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=22448, ...}) = 0
mmap(NULL, 24592, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b1200000
mmap(0x6b90b1202000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b1202000
mmap(0x6b90b1204000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x6b90b1204000
mmap(0x6b90b1205000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x6b90b1205000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libpulse.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260\326\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=338832, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6b90b21f6000
mmap(NULL, 340040, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b11a8000
mprotect(0x6b90b11b4000, 282624, PROT_NONE) = 0
mmap(0x6b90b11b4000, 192512, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x6b90b11b4000
mmap(0x6b90b11e3000, 86016, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3b000) = 0x6b90b11e3000
mmap(0x6b90b11f9000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x50000) = 0x6b90b11f9000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libsndio.so.7.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`7\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=59616, ...}) = 0
mmap(NULL, 71136, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b1190000
mmap(0x6b90b1193000, 32768, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x6b90b1193000
mmap(0x6b90b119b000, 12288, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xb000) = 0x6b90b119b000
mmap(0x6b90b119e000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd000) = 0x6b90b119e000
mmap(0x6b90b11a0000, 5600, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x6b90b11a0000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libXext.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0007\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=73424, ...}) = 0
mmap(NULL, 2169112, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0f78000
mprotect(0x6b90b0f89000, 2093056, PROT_NONE) = 0
mmap(0x6b90b1188000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x10000) = 0x6b90b1188000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libXcursor.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\3605\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=47768, ...}) = 0
mmap(NULL, 49944, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0f68000
mmap(0x6b90b0f6b000, 24576, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x6b90b0f6b000
mmap(0x6b90b0f71000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9000) = 0x6b90b0f71000
mmap(0x6b90b0f73000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa000) = 0x6b90b0f73000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libXinerama.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\21\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=14496, ...}) = 0
mmap(NULL, 16680, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0f60000
mmap(0x6b90b0f61000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x6b90b0f61000
mmap(0x6b90b0f62000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b0f62000
mmap(0x6b90b0f63000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b0f63000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libXrandr.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\320\34\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=43384, ...}) = 0
mmap(NULL, 2138568, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0d50000
mprotect(0x6b90b0d5a000, 2093056, PROT_NONE) = 0
mmap(0x6b90b0f59000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9000) = 0x6b90b0f59000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libXxf86vm.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\240\17\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=22816, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6b90b21f4000
mmap(NULL, 2117992, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0b48000
mprotect(0x6b90b0b4d000, 2093056, PROT_NONE) = 0
mmap(0x6b90b0d4c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x6b90b0d4c000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libwayland-cursor.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P\"\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=35200, ...}) = 0
mmap(NULL, 37360, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0b38000
mmap(0x6b90b0b3a000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b0b3a000
mmap(0x6b90b0b3c000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x6b90b0b3c000
mmap(0x6b90b0b3d000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x6b90b0b3d000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libxkbcommon.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 U\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=264904, ...}) = 0
mmap(NULL, 266904, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0af0000
mprotect(0x6b90b0af5000, 237568, PROT_NONE) = 0
mmap(0x6b90b0af5000, 110592, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0x6b90b0af5000
mmap(0x6b90b0b10000, 122880, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x20000) = 0x6b90b0b10000
mmap(0x6b90b0b2f000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3e000) = 0x6b90b0b2f000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libxcb.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\307\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=166824, ...}) = 0
mmap(NULL, 169096, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0ac0000
mmap(0x6b90b0acc000, 77824, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x6b90b0acc000
mmap(0x6b90b0adf000, 36864, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1f000) = 0x6b90b0adf000
mmap(0x6b90b0ae8000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x27000) = 0x6b90b0ae8000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libGLdispatch.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\200\2\4\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=637384, ...}) = 0
mmap(NULL, 771184, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0a00000
mprotect(0x6b90b0a40000, 208896, PROT_NONE) = 0
mmap(0x6b90b0a40000, 126976, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x40000) = 0x6b90b0a40000
mmap(0x6b90b0a5f000, 77824, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5f000) = 0x6b90b0a5f000
mmap(0x6b90b0a73000, 172032, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x72000) = 0x6b90b0a73000
mmap(0x6b90b0a9d000, 128112, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x6b90b0a9d000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libffi.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\320\"\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=35224, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6b90b21f2000
mmap(NULL, 38504, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b09f0000
mmap(0x6b90b09f2000, 20480, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b09f2000
mmap(0x6b90b09f7000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x6b90b09f7000
mmap(0x6b90b09f8000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x6b90b09f8000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libz.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\320#\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=121280, ...}) = 0
mmap(NULL, 2216336, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b07d0000
mprotect(0x6b90b07ec000, 2097152, PROT_NONE) = 0
mmap(0x6b90b09ec000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1c000) = 0x6b90b09ec000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libexpat.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000A\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=243840, ...}) = 0
mmap(NULL, 245920, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0790000
mprotect(0x6b90b0794000, 221184, PROT_NONE) = 0
mmap(0x6b90b0794000, 135168, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x6b90b0794000
mmap(0x6b90b07b5000, 81920, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x25000) = 0x6b90b07b5000
mmap(0x6b90b07ca000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x39000) = 0x6b90b07ca000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libuuid.so.1", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=35352, ...}) = 0
mmap(NULL, 37296, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0780000
mmap(0x6b90b0782000, 20480, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b0782000
mmap(0x6b90b0787000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x6b90b0787000
mmap(0x6b90b0788000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x6b90b0788000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libpng16.so.16", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0Pi\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=227248, ...}) = 0
mmap(NULL, 229392, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0740000
mmap(0x6b90b0746000, 151552, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x6b90b0746000
mmap(0x6b90b076b000, 49152, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2b000) = 0x6b90b076b000
mmap(0x6b90b0777000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x36000) = 0x6b90b0777000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260\304\10\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=1570256, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6b90b20ae000
mmap(NULL, 1585184, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b05b8000
mprotect(0x6b90b0641000, 962560, PROT_NONE) = 0
mmap(0x6b90b0641000, 704512, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x89000) = 0x6b90b0641000
mmap(0x6b90b06ed000, 253952, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x135000) = 0x6b90b06ed000
mmap(0x6b90b072c000, 49152, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x173000) = 0x6b90b072c000
mmap(0x6b90b0738000, 12320, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x6b90b0738000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\3402\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=100712, ...}) = 0
mmap(NULL, 103472, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0598000
mprotect(0x6b90b059b000, 86016, PROT_NONE) = 0
mmap(0x6b90b059b000, 69632, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x6b90b059b000
mmap(0x6b90b05ac000, 12288, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x6b90b05ac000
mmap(0x6b90b05b0000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17000) = 0x6b90b05b0000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libGLX.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`4\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=76336, ...}) = 0
mmap(NULL, 210528, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0560000
mprotect(0x6b90b0563000, 61440, PROT_NONE) = 0
mmap(0x6b90b0563000, 45056, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x6b90b0563000
mmap(0x6b90b056e000, 12288, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0x6b90b056e000
mmap(0x6b90b0572000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x11000) = 0x6b90b0572000
mmap(0x6b90b0574000, 128608, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x6b90b0574000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/pulseaudio/tls/x86_64/x86_64/libpulsecommon-12.2.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/pulseaudio/tls/x86_64/x86_64", 0x789886205a00) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/pulseaudio/tls/x86_64/libpulsecommon-12.2.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/pulseaudio/tls/x86_64", 0x789886205a00) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/pulseaudio/tls/libpulsecommon-12.2.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/pulseaudio/tls", 0x789886205a00) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/pulseaudio/x86_64/x86_64/libpulsecommon-12.2.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/pulseaudio/x86_64/x86_64", 0x789886205a00) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/pulseaudio/x86_64/libpulsecommon-12.2.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/pulseaudio/x86_64", 0x789886205a00) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/pulseaudio/libpulsecommon-12.2.so", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0po\1\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=542888, ...}) = 0
mmap(NULL, 545784, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b04d8000
mprotect(0x6b90b04ec000, 454656, PROT_NONE) = 0
mmap(0x6b90b04ec000, 294912, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x6b90b04ec000
mmap(0x6b90b0534000, 155648, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5c000) = 0x6b90b0534000
mmap(0x6b90b055b000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x82000) = 0x6b90b055b000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/pulseaudio/libcap.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libcap.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\"\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=26864, ...}) = 0
mmap(NULL, 29016, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b04d0000
mprotect(0x6b90b04d2000, 16384, PROT_NONE) = 0
mmap(0x6b90b04d2000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b04d2000
mmap(0x6b90b04d4000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x6b90b04d4000
mmap(0x6b90b04d6000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0x6b90b04d6000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/pulseaudio/libdbus-1.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libdbus-1.so.3", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000\355\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=386912, ...}) = 0
mmap(NULL, 389496, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0470000
mmap(0x6b90b047d000, 241664, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd000) = 0x6b90b047d000
mmap(0x6b90b04b8000, 86016, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x48000) = 0x6b90b04b8000
mmap(0x6b90b04cd000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5c000) = 0x6b90b04cd000
mmap(0x6b90b04cf000, 376, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x6b90b04cf000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libbsd.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0pH\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=96568, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6b90b20ac000
mmap(NULL, 102768, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0450000
mprotect(0x6b90b0454000, 77824, PROT_NONE) = 0
mmap(0x6b90b0454000, 61440, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x6b90b0454000
mmap(0x6b90b0463000, 12288, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x13000) = 0x6b90b0463000
mmap(0x6b90b0467000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x16000) = 0x6b90b0467000
mmap(0x6b90b0469000, 368, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x6b90b0469000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libXrender.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\33\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=39480, ...}) = 0
mmap(NULL, 2134664, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0240000
mprotect(0x6b90b0249000, 2093056, PROT_NONE) = 0
mmap(0x6b90b0448000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8000) = 0x6b90b0448000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libXau.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`\16\0\0\0\0\0\0"..., 832) = 832
mmap(NULL, 2109728, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90b0038000
mprotect(0x6b90b003a000, 2097152, PROT_NONE) = 0
mmap(0x6b90b023a000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90b023a000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libXdmcp.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\23\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=22728, ...}) = 0
mmap(NULL, 2117872, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90afe30000
mprotect(0x6b90afe35000, 2093056, PROT_NONE) = 0
mmap(0x6b90b0034000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x6b90b0034000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libX11-xcb.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\20\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=14128, ...}) = 0
mmap(NULL, 16424, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90afe28000
mmap(0x6b90afe29000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x6b90afe29000
mmap(0x6b90afe2a000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90afe2a000
mmap(0x6b90afe2b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90afe2b000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libICE.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360N\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=102496, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6b90b2026000
mmap(NULL, 2212128, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90afc08000
mprotect(0x6b90afc1f000, 2097152, PROT_NONE) = 0
mmap(0x6b90afe1f000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17000) = 0x6b90afe1f000
mmap(0x6b90afe21000, 12576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x6b90afe21000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libSM.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0p\"\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=39144, ...}) = 0
mmap(NULL, 41320, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90afbf8000
mmap(0x6b90afbfa000, 20480, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x6b90afbfa000
mmap(0x6b90afbff000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x6b90afbff000
mmap(0x6b90afc01000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8000) = 0x6b90afc01000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libXtst.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`\24\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=22976, ...}) = 0
mmap(NULL, 2118200, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90af9f0000
mprotect(0x6b90af9f5000, 2093056, PROT_NONE) = 0
mmap(0x6b90afbf4000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x6b90afbf4000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/tls/x86_64/x86_64/libsystemd.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu/tls/x86_64/x86_64", 0x7898862058a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/tls/x86_64/libsystemd.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu/tls/x86_64", 0x7898862058a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/tls/libsystemd.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu/tls", 0x7898862058a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/x86_64/x86_64/libsystemd.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu/x86_64/x86_64", 0x7898862058a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/x86_64/libsystemd.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu/x86_64", 0x7898862058a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libsystemd.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/lib/x86_64-linux-gnu", {st_mode=S_IFDIR|0755, st_size=16384, ...}) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/tls/x86_64/x86_64/libsystemd.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/tls/x86_64/x86_64", 0x7898862058a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/tls/x86_64/libsystemd.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/tls/x86_64", 0x7898862058a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/tls/libsystemd.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/tls", 0x7898862058a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/x86_64/x86_64/libsystemd.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/x86_64/x86_64", 0x7898862058a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/x86_64/libsystemd.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat("/usr/lib/x86_64-linux-gnu/x86_64", 0x7898862058a0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libsystemd.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360\26\1\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=830880, ...}) = 0
mmap(NULL, 834920, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90af920000
mmap(0x6b90af930000, 593920, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x10000) = 0x6b90af930000
mmap(0x6b90af9c1000, 159744, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa1000) = 0x6b90af9c1000
mmap(0x6b90af9e8000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc7000) = 0x6b90af9e8000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libwrap.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\3606\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=43880, ...}) = 0
mmap(NULL, 47424, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90af910000
mmap(0x6b90af913000, 20480, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x6b90af913000
mmap(0x6b90af918000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8000) = 0x6b90af918000
mmap(0x6b90af91a000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9000) = 0x6b90af91a000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libsndfile.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0Px\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=495728, ...}) = 0
mmap(NULL, 507520, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90af890000
mmap(0x6b90af897000, 335872, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x6b90af897000
mmap(0x6b90af8e9000, 118784, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x59000) = 0x6b90af8e9000
mmap(0x6b90af906000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x75000) = 0x6b90af906000
mmap(0x6b90af90a000, 7808, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x6b90af90a000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libasyncns.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\22\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=22368, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6b90b201e000
mmap(NULL, 2117648, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90af688000
mprotect(0x6b90af68d000, 2093056, PROT_NONE) = 0
mmap(0x6b90af88c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x6b90af88c000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libnsl.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260F\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=89016, ...}) = 0
mmap(NULL, 100952, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90af668000
mmap(0x6b90af66c000, 49152, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x6b90af66c000
mmap(0x6b90af678000, 20480, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x10000) = 0x6b90af678000
mmap(0x6b90af67d000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x6b90af67d000
mmap(0x6b90af67f000, 6744, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x6b90af67f000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libFLAC.so.8", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\217\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=489408, ...}) = 0
mmap(NULL, 2584608, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90af3f0000
mprotect(0x6b90af466000, 2093056, PROT_NONE) = 0
mmap(0x6b90af665000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x75000) = 0x6b90af665000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libogg.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\32\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=34688, ...}) = 0
mmap(NULL, 2129936, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90af1e0000
mprotect(0x6b90af1e8000, 2093056, PROT_NONE) = 0
mmap(0x6b90af3e7000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x6b90af3e7000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libvorbis.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360E\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=182184, ...}) = 0
mmap(NULL, 184336, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90af1b0000
mprotect(0x6b90af1b4000, 163840, PROT_NONE) = 0
mmap(0x6b90af1b4000, 90112, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x6b90af1b4000
mmap(0x6b90af1ca000, 69632, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1a000) = 0x6b90af1ca000
mmap(0x6b90af1dc000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2b000) = 0x6b90af1dc000
close(3) = 0
openat(AT_FDCWD, "/usr/lib/x86_64-linux-gnu/libvorbisenc.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260@\1\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=694248, ...}) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6b90b201c000
mmap(NULL, 696400, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90af100000
mmap(0x6b90af114000, 12288, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x6b90af114000
mmap(0x6b90af117000, 487424, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17000) = 0x6b90af117000
mmap(0x6b90af18e000, 118784, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8d000) = 0x6b90af18e000
close(3) = 0
openat(AT_FDCWD, "/lib/x86_64-linux-gnu/libresolv.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\240C\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=93000, ...}) = 0
mmap(NULL, 105088, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6b90af0e0000
mprotect(0x6b90af0e4000, 73728, PROT_NONE) = 0
mmap(0x6b90af0e4000, 53248, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x6b90af0e4000
mmap(0x6b90af0f1000, 16384, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x11000) = 0x6b90af0f1000
mmap(0x6b90af0f6000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x15000) = 0x6b90af0f6000
mmap(0x6b90af0f8000, 6784, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x6b90af0f8000
close(3) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6b90b201a000
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6b90b200e000
mmap(NULL, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x6b90b200b000
arch_prctl(ARCH_SET_FS, 0x6b90b200b840) = 0
mprotect(0x6b90b14c7000, 16384, PROT_READ) = 0
mprotect(0x6b90af0f6000, 4096, PROT_READ) = 0
mprotect(0x6b90af3e7000, 4096, PROT_READ) = 0
mprotect(0x6b90b2009000, 4096, PROT_READ) = 0
mprotect(0x6b90af1dc000, 4096, PROT_READ) = 0
mprotect(0x6b90af18e000, 114688, PROT_READ) = 0
mprotect(0x6b90af665000, 8192, PROT_READ) = 0
mprotect(0x6b90af67d000, 4096, PROT_READ) = 0
mprotect(0x6b90b171b000, 4096, PROT_READ) = 0
mprotect(0x6b90af88c000, 4096, PROT_READ) = 0
mprotect(0x6b90af906000, 12288, PROT_READ) = 0
mprotect(0x6b90af91a000, 4096, PROT_READ) = 0
mprotect(0x6b90b04d6000, 4096, PROT_READ) = 0
mprotect(0x6b90af9e8000, 12288, PROT_READ) = 0
mprotect(0x6b90b023a000, 4096, PROT_READ) = 0
mprotect(0x6b90b2018000, 4096, PROT_READ) = 0
mprotect(0x6b90b0467000, 4096, PROT_READ) = 0
mprotect(0x6b90b0034000, 4096, PROT_READ) = 0
mprotect(0x6b90b0ae8000, 4096, PROT_READ) = 0
mprotect(0x6b90b2023000, 4096, PROT_READ) = 0
mprotect(0x6b90b1e7b000, 4096, PROT_READ) = 0
mprotect(0x6b90b1188000, 4096, PROT_READ) = 0
mprotect(0x6b90b1d3e000, 4096, PROT_READ) = 0
mprotect(0x6b90afbf4000, 4096, PROT_READ) = 0
mprotect(0x6b90b0788000, 4096, PROT_READ) = 0
mprotect(0x6b90afe1f000, 4096, PROT_READ) = 0
mprotect(0x6b90afc01000, 4096, PROT_READ) = 0
mprotect(0x6b90afe2b000, 4096, PROT_READ) = 0
mprotect(0x6b90b0448000, 4096, PROT_READ) = 0
mprotect(0x6b90b04cd000, 4096, PROT_READ) = 0
mprotect(0x6b90b055b000, 8192, PROT_READ) = 0
mprotect(0x6b90b0a73000, 167936, PROT_READ) = 0
mprotect(0x6b90b0572000, 4096, PROT_READ) = 0
mprotect(0x6b90b05b0000, 4096, PROT_READ) = 0
mprotect(0x6b90b072c000, 40960, PROT_READ) = 0
mprotect(0x6b90b09ec000, 4096, PROT_READ) = 0
mprotect(0x6b90b0777000, 4096, PROT_READ) = 0
mprotect(0x6b90b07ca000, 8192, PROT_READ) = 0
mprotect(0x6b90b09f8000, 4096, PROT_READ) = 0
mprotect(0x6b90b0b2f000, 8192, PROT_READ) = 0
mprotect(0x6b90b187e000, 8192, PROT_READ) = 0
mprotect(0x6b90b0b3d000, 4096, PROT_READ) = 0
mprotect(0x6b90b0d4c000, 4096, PROT_READ) = 0
mprotect(0x6b90b0f59000, 4096, PROT_READ) = 0
mprotect(0x6b90b0f63000, 4096, PROT_READ) = 0
mprotect(0x6b90b1b2c000, 4096, PROT_READ) = 0
mprotect(0x6b90b0f73000, 4096, PROT_READ) = 0
mprotect(0x6b90b1300000, 32768, PROT_READ) = 0
mprotect(0x6b90b119e000, 4096, PROT_READ) = 0
mprotect(0x6b90b11f9000, 8192, PROT_READ) = 0
mprotect(0x6b90b1205000, 4096, PROT_READ) = 0
mprotect(0x6b90b1550000, 106496, PROT_READ) = 0
mprotect(0x6b90b15df000, 4096, PROT_READ) = 0
mprotect(0x6b90b169c000, 28672, PROT_READ) = 0
mprotect(0x6b90b16eb000, 8192, PROT_READ) = 0
mprotect(0x6b90b1923000, 4096, PROT_READ) = 0
mprotect(0x6b90b188b000, 4096, PROT_READ) = 0
mprotect(0x6b90b21e1000, 20480, PROT_READ) = 0
mprotect(0x6b90b16f7000, 4096, PROT_READ) = 0
mprotect(0x6b90b184c000, 81920, PROT_READ) = 0
mprotect(0x6b90b18a3000, 4096, PROT_READ) = 0
mprotect(0x6b90b20a9000, 4096, PROT_READ) = 0
mprotect(0x6b90b191d000, 8192, PROT_READ) = 0
mprotect(0x6b90b18df000, 4096, PROT_READ) = 0
mprotect(0x69d5e1b2000, 4096, PROT_READ) = 0
mprotect(0x6b90b224f000, 4096, PROT_READ) = 0
munmap(0x6b90b21f8000, 150225) = 0
set_tid_address(0x6b90b200bb10) = 1830
set_robust_list(0x6b90b200bb20, 24) = 0
rt_sigaction(SIGRTMIN, {sa_handler=0x6b90b17066b0, sa_mask=[], sa_flags=SA_RESTORER|SA_SIGINFO, sa_restorer=0x6b90b1712730}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {sa_handler=0x6b90b1706740, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART|SA_SIGINFO, sa_restorer=0x6b90b1712730}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
prlimit64(0, RLIMIT_STACK, NULL, {rlim_cur=8192*1024, rlim_max=RLIM64_INFINITY}) = 0
futex(0x6b90b20240c8, FUTEX_WAKE_PRIVATE, 2147483647) = 0
brk(0x69d6f104c84) = 0x69d6f104c84
brk(0x69d6f105000) = 0x69d6f105000
getuid() = 0
write(2, " 76371410064 [E] m"..., 112 76371410064 [E] main.c:2268 | main | Do not run looking glass as root!
) = 112
getpid() = 1830
getpid() = 1830
exit_group(-1) = ?
+++ exited with 255 +++
System:
OS: Devuan GNU/Linux 3 (beowulf) x86_64
Host: KGP(M)E-D16
Kernel: 5.9.1-hardened-r4.9-aio
Uptime: 21 hours, 24 mins
Packages: 2282 (dpkg)
Shell: bash 5.0.3
Resolution: 1920x1200
DE: Xfce
WM: Xfwm4
WM Theme: Bear2
Theme: Xfce-stellar [GTK2]
Icons: GNUstep [GTK2]
Terminal: xfce4-terminal
Terminal Font: Liberation Mono Bold 9
CPU: AMD Opteron 6386 SE (32) @ 2.800GHz
GPU: NVIDIA GeForce GTX 750 Ti
GPU: NVIDIA GeForce GTX 1070
Memory: 22305MiB / 128704MiB
