Fan and AIO pump config questions for H14SSL-N
I’m building a workstation based on the H14SSL-N and I plan to use the Silverstone XE360-SP5 for cooling the CPU.
The problem/question I have is, I have not seen any way to take a single fan header and set it to always run at full ‘speed’ (for the AIO pump) nor a way to set a traditional ‘fan curve’ based on CPU temp. It would be nice as well to have the ability to set fan curves for fans on other headers as well in addition to the FANS/Pump for the AIO.
I have looked in the BMC, and used the IPMIView tool, as well as checked the manual for this info. In the IPMI view tool I found where I could select different presets, but nothing that lets me set a traditional temp based fan curve like one would use in a consumer grade system.
It’s entirely possible I’ve missed something, but if anyone could point me to a comprehensive guide for configuring the fan headers on the H14SSL motherboard (or any advice to that end) I would greatly appreciate it.
Welcome!
I’ve completely given up being able to set sane fan curves on my H13 board and opted for a 3rd party fan controller.
If you’re on Linux, there’s a project called smfc that aims to give fine grain control over the fans on a Supermicro board by running a systemd service that spams raw commands to the AST chip while monitoring sensor outputs.
I haven’t actually used it myself so I can’t say how well it works, and it doesn’t have official support for H14 boards yet (but probably works on them anyways).
Thanks for the reply! It’s too bad Super Micro doesnt seem to have some native way to do it, at least for things like the H13/H14 that are likely getting used a decent amount for workstation builds, but it’s cool a tool like that has been made, I appreciate the heads up!
smfc 6.0.0 just released with an experimental X14/H14 support, you can give it a try.
