So I just reinstalled Fallout 4 and I'm having a strange issue. It starts in borderless and window mode checked every time even though I uncheck it. There are no resolutions to choose from. I am playing in 4k with sli. So far I've tried reinstalling Fallout. I've tried editing prefs file, forcing res in steam. Nothing seems to be working.. I am running the beta for steam.. I'm not sure what to make of it.
Could be the beta your using. That's my only guess. Unfortunately this game is suuuuuper buggy
oops I was wrong I wasn't even using steam beta yet....I had also reinstalled steam.
I've had the same problem from time to time (also running the beta), and I've changed video drivers (AMD) several times, rebooting Windows seems to solve the problem sometimes, other times it doesn't and the game won't start just hanging with a black screen, I just keep trying to load the game and eventually it loads as it's suppose to, but honestly the game is really buggy on some systems hopefully it'll get patched soon.
Switch the aspect ratio to 16:10, then switch back to 16:9. Should display your resolution list again.
Also, I'm not sure you can run true 4k, only UHD. I got major scaling issues at 4096x2160, but 3840x2160 works great. Of course, this could be because my monitor(B400) should only be 3840, but Crimson unlocked 4096(by some voodoo magic) and actually recommends it as my native resolution. However, in FO4 the UI and scope when scoped in don't scale fully in full screen.
Yup....seen that on mine also, I thought it was because I was also using beta AMD drivers but I've rolled the drivers back and switched to Crimson, I don't see the issue your having any more but still have it load in a windows sometimes when that box isn't checked, or just hang loading, or it loads fine, it's very weird behavior.
ill try it but it resets everything I do. Also it doesn't show anything above 1080p when I actually get the resolutions to show up.
When I uncheck window, it sets it at 800x600. I did set res at 3840x2160 manually in pref and steam...nothing is working... weird.............
looks like I need to wait for a patch or something.
