Has anyone had any luck fixing the user interface on custom resolutions in Fallout 4? I have been checking Flawless Widescreen religiously to see if any thing has come up. I also tried to do the fix that I did in fallout 3 to no avail.
have you tried just going into the ini and typing in the resolution you want?
yes, that's not the problem. when you do that all the HUD gets stretched out and just is buggy.
I'm running the game at 3440x1440 edited through the ini file as well as using a few mods that scale the UI for it better.
do you have a link to the mods on nexus?
and are you using 1 monitor? I have a 5760x1080 triple monitor setup
Yes I'm using 1 monitor, 3440x1440 21:9 ultra wide.
Another one.
I usually fiddle around with it until it works, a bit sad that they didn't support 21:9 in the UI.
