External Speakers Not Working via KVM
KVM: HDMI 2.1 KVM w/EDID & Serial Control - Dual Monitor - Four Computer
Speakers: Bose Companion 20 multimedia speaker system]
I have the 3.5mm from the speakers put into the KVM. My previous KVM only needed that connection and the speakers worked on each device as I switched over. On this one though, it doesn’t. Is this because I don’t also have 3.5mm going to each device individually?
Yes, but you can buy a cheap USB DAC to fix this:
^^ plug this into one of the KVM’s USB ports, and your problem should be fixed.
