I have been trying to transfer files from my pi4 to an external hard drive and it momentarily cuts out every so often. Anyone have an idea as to why? It will immediately reconnect but interrupts the tranfers
It’s not the USB controller overheating is it?
Does any part of the pi seem particularly hot?
Anything showing on dmesg?
I’m new to pi overall, how would I check? It also is a non external powered drive if that matters
If there is a “tools” or “apps” menu at the top, can you open a terminal window, and paste in the command:
dmesg | grep usb
I’m now thinking it might not have a lot of useful output, but can’t hurt? [edited]
Let’s assume it is a heat issue, what could be done to minimize that…there are already heat sinks on it
If it does the connect/disconect thing when plugged into the USB2 socket, then it’s not the USB3 controller
It is in a USB 3.0 port
I could be wrong, but I seem to remember something up with the USB3 controller, so the USB2 is worth trying?
I’ll give that a try and report back
So far that seems to have solved the problem, thanks
Pi 4 is very sensitive to the power supply voltage spikes if you use the USB 3.0 ports with high power draw devices, some external drives can draw too much power due to their USB 3 to SATA bridge chipset(WD MyPassport is known for this).
Yeah, I think the OP anticipated this, which is why he mentioned the drives are externally powered.
But with spinning HDD’s this is something to be aware of.
I think OP might just need to Google the USB controller chip, and maybe hold a finger against it. If it is too holt to touch when busy, then a heat sink might help. Unless he already heart dunked it like he mentioned.
I havent heat debunked it entirely. Since moving the non-powered drive over to USB 2 I have not observed the issue anymore. The pi I bought came with heatsinks, I have not yet confirmed if one of them is for the USB controller, but I also would like to find a more precise way to measure temperature aside from just feeling it.
There are probably temperature sensors on board. In fact, I know there is for the CPU, but not sure about the USB.
And not being silly, but if it is not too hot to handle, it is probably not a heat issue.
The devices are really good for the money, and stable, but at the end of the day, they are cheap boards, and some of the parts might just not be very good?
I’m open to anyone who knows better, especially about sensors, and if there is an easy app to download to check the sensors
He should also look into the controller on the external drive chassis.
A recent example is external m.2 nvme to usb 3 adapters. Some chips are known to have big issues with cutting out randomly, so attention is needed about getting a case with a known good chip.
