Explorer task hangs on trying to read Properties of several drives
Built a TV media server PC, which has two 3.5" external drives connected (at first, by the means of usb hubs). Whenever I try to access the Properties from Context menu (only from “My computer”, with all the drives listed), the Explorer basically hangs. I can access the drives, do all the IO stuff, and can access the same menu after opening the drive itself.
At first I thought this is a problem of the oneboard Odroid H3+ I was using. But recently gave up on the LEGO idea and moved everything to my old Phanteks case with a 9900k (the drives moved to a direct SATA connection), and it turns out the problem persisted.
I did reuse the m.2 drive from the Odroid, and it holds the same Windows install, so this is my “Suspect A” for the moment. I do admit that reinstalling the whole thing is a headache and I wish to avoid it.
So I have a “Suspect B”, which also is a possibility. The drives. Although the drives were bought in different time periods, and aren’t even the same models, I did use a chinese brand HDD external case to initialize them (through Windows). I’m not sure if its even possible to corrupt a drive in such manner, but not crossing this out.
Any ideas where to look and how to dig into this problem?
I would start with checking windows event viewer for errors. Could be something within windows that’s derping or hardware error is occurring.
Another tool that could help is this: Process Explorer - Sysinternals | Microsoft Learn
Use it all the time at work when dealing with buggy vendor software and it’s pretty good at helping found out what processes are borked.
Wouldn’t hurt to check drive health with something like crystal disk info.
Beyond that, I’d probably do a reimage.
