Background
I’ve built 3x ZFS systems now and none of them used anything more than spinning rust.
I’ve been saving up for a while now and I have everything I need to pack a Lenovo P520 Workstation to the gills. The problem is I’m not 100% sure how I should provision all the pools.
The purpose
I’m looking to de-google my life via nextcloud and run either Truenas or Ubuntu server but I’m still undecided. I need primary SSD storage for fast Truenas / Nextcloud operations and the spinning rust is for sequential backups / snapshots. I’ll need a cloudflare reverse proxy docker container as well.
The machine
At a high level the P520 has support for:
7x onboard sata
5x onboard PCI-e (mix of 4x, 8x, 16x)
2x onboard m.2 (pci-e)
My equipment
Here’s what I have:
1x HBA
6x 256GB sata SSDs (used/mixed)
5x 1.6TB intel P3600 pci-e AIC (used, 0TB written)
6x 6TB HGST SATA HDDs (used, 30,000 POHours)
2x Intel Optane P1600X 118GB (new)
Build with HBA + extra SATA SSDs
Here’s what I could do if I want to use the HBA+janky SSDs:
1x 256GB SATA SSD (boot)
4x 1.6TB intel P3600
1x HBA
6x 6TB HDST (SATA)
5x 256GB SATA SSD (HBA - slog? zil? no idea)
2x Intel Optane (Metadata special for HDDs)
Simpler build without HBA
Alternatively, I could ditch the janky SSDs and go all-in with the intel AIC’s:
6x 6TB HDST (SATA)
My thoughts
This would be my first headless machine so I’d have to pull a PCI-e drive if anything serious happens to the machine so reliability seems like a good focus.
All I really know for sure is that I think the optanes would work best in a mirror for metadata special for the HDDs. It’s just kinda scary trusting all the metadata to only 2 drives even if they are optane.
For the HDDs I’m thinking RZ2 since these are backups anyways so it would take an intel drive failing and 2+ HDDs failing for a full data loss. I could be convinced to do RZ3 though.
Open to suggestions though! I have a bit of spare budget leftover for small hardware changes if necessary.
potential vdev 1 - a
4x intel P3600 in RZ1 for truenas storage
nightly snapshots to vdev2
potential vdev 2 - a
5x SATA SSD in RZ2 for write cache
2x intel optane in mirror for metadata
6x HGST 6TB in RZ2 for bulk storage
potential vdev 1 - b
5x intel P3600 in RZ1 for truenas storage
potential vdev 2 - b
