Anyone here ever had a motherboard cause coil whine to come from the PSU?
Bought a Corsair rm750e, and it had coil whine, only when idle. Really bad though, like across the room bad.
Amazon had a replacement to me within the day. Same issue.
I have a video of this (second) one (the bad, unchangeable, thumbnail is just my hand lol)
So two bad (?) Corsair PSUs, I thought I’d get something off of that Cultist list. Got an NZXT 1200C total overkill, but it was only £30 more than the Corsairs, cool.
Nope. Even worse. It’s like Josh Wink’s Higher State Of Consciousness at points. Again it is fine under load.
So, that’s now 3 different PSUs, all with the same issue. Never had this with the previous PC. Sadly don’t have any spare parts to cross check things with.
Tried removing everything once at a time, RAM, SSDs, all peripherals. Tried different power cables, different sockets in different parts of the house.
Tried all sorts of BIOS settings, default, etc etc. It starts as soon as the power does (second video shows) and only stops if there’s a load on the CPU.
So, the only thing I’m left with is the motherboard??
Or the CPU? That seems unlikely as heck for some reason, and afaik it won’t even boot without it in there
I’m at the end of my rope here. I’ll probably just order another, different motherboard from Amazon and see.
Anyone of you ever experienced this though?
-edit- Ah, sadly I can’t include links to the videos I took. Just imagine really bad squeaking/screeching coil whine from hell.
ASUS Prime B650M-A WIFI II
Corsair 6000/c30 RAM (from the compatibility list)
AMD 7800x3d
