Evega GTX 770 superclocked 2gb or Asus HD 7970 direct cu ii?
i usually play dayz standalone and arma 3 and csgo pls help
Both are pretty equal. Great performing cards! I would suggest getting the cheapest card.
They are the same.
If you are in the US, get the 770. If you can find them for the same price, get the 7970.
