Live in US but received GTR 7 Pro with an EU psu, will a simple adapter suffice?
If the power supply says it can do 100-240V at 50-60Hz then a simple adaptor will suffice
if it has no markings or you can’t discern whether it can do not attempt to plug it in, you can hurt yourself or the machine
Thanks so much for the speedy reply much appreciated. This EU PSU is marked as follows “Input 200-240v~50/60Hz, 0.8A” which differs from what you state “100-240 at 50-60 HZ240V”.
then it is incompatible, you will need a US power supply for it
That’s easier said than done with Beelink. Ordered from AliExpress and was anticipating problems. But thanks alot for the info, cheers and Happy New Year!
That’s going to be rough. The Beelink uses a custom looking magnetic connector and not a standard barrel jack…
you have the option of a step-up transformer since the supply can allegedly do 60Hz, but it’ll add bulk and cost
