I recently picked up a 4 Port power monitor hat for the Wemos ESP32-S2 based boards from MattramLabs - MLP201191 - ESP32 S2 4-Channel Mains Power Sensor - https://mottramlabs.com/ct_products.html
I will likely use this thread as a bit of a running log on trying to get this dam thing working as there seems to be bugger all documentation and its a bit of the deepest I have gone through in getting something that is essentially just a hat with minimal documentation working.
Beaware of DOA Wemos ESP32-S2 Boards. My first 2 boards were DOA and I had spent days trying to get them to connect to my PC. If when you hold the ‘0’ button and plug in the USB cable, if no USB ding happens on the PC, the board is dead and get another one.
ESP Home Flashing of Files
ESPHome on Home Assistant never wants to flash. I could say the same for the web ESPHome tool as well. I had to use the Adafruit online tool and use an exported file from my HA device. I stumbled across a video which helped.
Below are the notes I made as I went for getting that to flash for the first time. I have repeated that a few times until OTA from Home Assistant ESPhome tool would work reliably using the ‘flashing wirelessly’ function.
Video on how to do it
Adafruit Web Serial ESPTool
How to get the .bin file
Will likely need to copy the factory-fimware.bin file from within Home Assistant - Access ESPHOME file system to retrieve .elf build file - #5 by nickrout - ESPHome - Home Assistant Community
Make sure the terminal promiscuous mode is turned off
Can use this command to get to the folder area for the addon
docker exec -it $(docker ps|sed -rne 's/(.+)(addon_.{8}_esphome)/\2/p') bash
You will then need to use the location where the bin file was generated in the Home assistant ESPhome dashboard. In the past it has gone to here
cd /data/build/wemoss2-4-port/.pioenvs/wemoss2-4-port/
You will have to copy the file to somewhere you can access via samba/ssh/etc
cp /firmware-factory.bin /config/
the file will then be on the /config directory to copy to pc for flashing.
Developing a YAML
With the limited docs i went searching and within the issues section I had located on the github this bit of code
substitutions:
update_time: never
disp_name: "house-power-sensor"
esphome:
friendly_name: house-power-sensor
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
level: debug
# Enable Home Assistant API
api:
encryption:
key: "USE YOUR ENCRYPTION KEY HERE"
ota:
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
ap:
ssid: "house-power-sensor"
password: "PROVIDE AP PASSWORD"
time:
- platform: homeassistant
interval:
- interval: 5s
then:
- script.execute: readCTs
script:
- id: readCTs
then:
- component.update: ct1Amps
- delay: 500ms
- component.update: ct1Watts
- delay: 500ms
- component.update: ct2Amps
- delay: 500ms
- component.update: ct2Watts
- delay: 500ms
- component.update: ct3Amps
- delay: 500ms
- component.update: ct3Watts
- delay: 500ms
- component.update: ct4Amps
- delay: 500ms
switch:
- platform: restart
sensor:
- platform: ct_clamp
sensor: adc_sensor_1
update_interval: never
sample_duration: 200ms
filters:
- calibrate_linear:
- 0 -> 0
- 0.07972 -> 7.72
- platform: adc
pin: GPIO34
attenuation: 11db
internal: true
sensor: adc_sensor_2
filters:
- calibrate_linear:
- 0 -> 0
- 0.08278 -> 7.71
- platform: adc
pin: GPIO35
attenuation: 11db
internal: true
sensor: adc_sensor_3
filters:
- calibrate_linear:
- 0 -> 0
- 0.08317 -> 7.84
- platform: adc
pin: GPIO36
attenuation: 11db
internal: true
sensor: adc_sensor_4
#filters:
#- calibrate_linear:
#- 0 -> 0
#- 0.08277 -> 7.80
- platform: adc
pin: GPIO39
attenuation: 11db
internal: true
- platform: wifi_signal
update_interval: 1min
- platform: uptime
#Watts per channel
- platform: template
lambda: return id(ct1Amps).state * id(ic1Volts).state;
accuracy_decimals: 0
unit_of_measurement: W
icon: "mdi:flash-circle"
lambda: return id(ct2Amps).state * id(ic1Volts).state;
lambda: return id(ct3Amps).state * id(ic1Volts).state;
- platform: total_daily_energy
name: CT1 Total kWh
power_id: ct1Watts
filters:
- multiply: 0.001
unit_of_measurement: kWh
icon: "mdi:flash"
name: CT2 Total kWh
power_id: ct2Watts
filters:
- multiply: 0.001
icon: "mdi:flash"
name: CT3 Total kWh
power_id: ct3Watts
filters:
- multiply: 0.001
icon: "mdi:flash"
lambda: return id(ct1Amps).state + id(ct2Amps).state + id(ct3Amps).state ;
accuracy_decimals: 2
unit_of_measurement: A
icon: "mdi:flash"
update_interval: 15s
lambda: return id(totalAmps).state * id(ic1Volts).state;
accuracy_decimals: 1
icon: "mdi:flash"
power_id: totalWatts
filters:
- multiply: 0.001
icon: "mdi:flash"
entity_id: sensor.house_voltage
internal: true
lambda: return id(ic1Volts).state;
unit_of_measurement: V
update_interval: 60s
After obtaining the code provided in the other issue - ESP Home Code · Issue #1 · Mottramlabs/ESP32-4-Channel-Mains-Current-Sensor · GitHub
I noticed that the ADC provided would list an error where it says
ESP32S2 doesn't support ADC on this pin.
Knocking over a fair bit of googling, etc I couldn’t get a grasp on it until i found that the ADC pins are slightly different.
Using this site here - https://www.studiopieters.nl/esp32-s2-pinout/
GPIO1 ADC1_CH0
GPIO2 ADC1_CH1
GPIO3 ADC1_CH2
GPIO4 ADC1_CH3
Don’t use the ADC2 pins listed as these are disabled for wifi
Digging through some more within the schematics of the 4 port board ESP32-4-Channel-Mains-Current-Sensor/SCH201191.pdf at main · Mottramlabs/ESP32-4-Channel-Mains-Current-Sensor · GitHub
It listed that the barrel jacks appear to go to 1, 2, 3 & 4.
I updated that code to change the GPIO to 1,2,3 & 4 and it validated and got it installed no issues.
Next issue it appeared is that it seemed like the device would randomly disconnect…
Originally i thought it was a power issue but digging through some more docs on ESPHome (WiFi Component - ESPHome - Smart Home Made Simple) it appears that there is a ‘light’ power save feature with these so that it must turn off/on wifi. This may be okay later down the line but when your trying to set the device up it makes it super frustrating it just disconnecting. Under the wifi listed the power saving as none.
wifi:
power_save_mode: none
This has stopped it disconnecting after about 90 seconds or so… This may also assist in getting the dam thing to flash as this disconnect would be a pain in trying to flash it OTA wirelessly during my updates/changes to the yaml.
I have been typing this out for a fair while now and the device is yet to disconnect =]
I found it easier to set a static IP so i have done this in both my DHCP settings within the router but have also backed this up within the device yaml with this from WiFi Component - ESPHome - Smart Home Made Simple
wifi:
manual_ip:
# Set this to the IP of the ESP
static_ip: 10.0.0.42
# Set this to the IP address of the router. Often ends with .1
gateway: 10.0.0.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
When you watch the device connect however it does not have any DNS listed so the addition of a DNS1 & DNS2 parameter into the wifi section above below subnet will get you sorted (if necessary)
In essence your WiFi section within the yaml would end up looking something like this
wifi:
# Optional manual IP
manual_ip:
gateway: 10.0.0.1
dns1: 10.0.0.1
#powersaving WiFi
I am yet to get this fully working or deployed but am using this a notes for getting through the issues as well as helping others who purchase it and have a bit of a WTF moment in trying to get it going.
