Error: No EDID read. Help!
Hi, hope this is in the right place. Fired up PC and saw “No EDID read” error. I’ve barely an idea what that even is. Browser returned “How to fix "no EDID read" on Linux 5.6.0” as the top answer; I barely understood a word of what you are supposed to do in this event; even whether it was critical or otherwise.
“xrandr --verbose” (below) seems to return the necessary information; but what do I know? My ignorant flaying around lately has left me not wanting to touch anything that might crash things that’ll take another week of ignorant flaying around to fix; so here I am. Does “xrandr --verbose” look right or do I need to take action? The linked topic’s answer is a little beyond me and any help would be appreciated. Thanks
Sorry, I’d attach “xandra --verbose”, but don’t know how. Output printed below:
deadtroopers@deadtroopers-System-Product-Name:~$ xrandr --verbose
Screen 0: minimum 320 x 200, current 5112 x 2130, maximum 16384 x 16384
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x54
Timestamp: 29643
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3 4 5
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
GAMMA_LUT_SIZE: 4096
range: (0, -1)
DEGAMMA_LUT_SIZE: 4096
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
CTM: 0
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
supported: off, on, auto
subconnector: Unknown
supported: Unknown, VGA, DVI-D, HDMI, DP, Wireless, Native
vrr_capable: 0
range: (0, 1)
max bpc: 8
range: (8, 16)
underscan vborder: 0
range: (0, 128)
underscan hborder: 0
range: (0, 128)
underscan: off
scaling mode: None
supported: None, Full, Center, Full aspect
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 65
supported: 65
non-desktop: 0
range: (0, 1)
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x55
Timestamp: 29643
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3 4 5
filter:
range: (0, -1)
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
CTM: 0
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
vrr_capable: 0
range: (0, 1)
max bpc: 8
range: (8, 16)
range: (0, 128)
range: (0, 128)
underscan: off
scaling mode: None
link-status: Good
CONNECTOR_ID: 70
supported: 70
non-desktop: 0
range: (0, 1)
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x56
Timestamp: 29643
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3 4 5
filter:
range: (0, -1)
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
CTM: 0
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
vrr_capable: 0
range: (0, 1)
max bpc: 8
range: (8, 16)
range: (0, 128)
range: (0, 128)
underscan: off
scaling mode: None
link-status: Good
CONNECTOR_ID: 74
supported: 74
non-desktop: 0
range: (0, 1)
HDMI-A-1 connected primary 5112x2130+0+0 (0x5a) normal (normal left inverted right x axis y axis) 874mm x 366mm
Identifier: 0x57
Timestamp: 29643
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1 2 3 4 5
Transform: 1.331238 0.000000 0.000000
0.000000 1.331238 0.000000
filter: bilinear
_MUTTER_PRESENTATION_OUTPUT: 0
EDID:
00ffffffffffff001e6dfb763b3c0100
011b010380572578eaca95a6554ea126
0f5054256b807140818081c0a9c0b300
d1c08100d1cfd8a40020f14068603020
7a006a6e3100001a85cf0020f1407460
30207a006a6e3100001a000000fd0038
4b1e7d36000a202020202020000000fc
004c4720554c545241574944450a01b3
020326f1230907074b100403011f1359
da1205148301000065030c00100067d8
5dc4016c800040510020f14050603020
7a006a6e3100001ae4a770b8d1a02450
906084006a6e3100001ae77c70a0d0a0
295030203a006a6e3100001a000000ff
003730314b4b465332433935350a0000
000000000000000000000000000000c3
range: (0, -1)
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
vrr_capable: 0
range: (0, 1)
max bpc: 8
range: (8, 16)
range: (0, 128)
range: (0, 128)
underscan: off
scaling mode: None
link-status: Good
CONNECTOR_ID: 78
supported: 78
non-desktop: 0
range: (0, 1)
3840x1600 (0x5a) 422.000MHz +HSync -VSync *current +preferred
h: width 3840 start 3888 end 3920 total 4128 skew 0 clock 102.23KHz
v: height 1600 start 1607 end 1617 total 1704 clock 59.99Hz
3840x1600 (0x5b) 531.250MHz +HSync -VSync
h: width 3840 start 3888 end 3920 total 4128 skew 0 clock 128.69KHz
v: height 1600 start 1607 end 1617 total 1716 clock 75.00Hz
3840x1600 (0x5c) 208.000MHz +HSync -VSync
h: width 3840 start 3888 end 3920 total 4128 skew 0 clock 50.39KHz
v: height 1600 start 1607 end 1617 total 1680 clock 29.99Hz
3440x1440 (0x5d) 429.800MHz +HSync -VSync
h: width 3440 start 3584 end 3680 total 3880 skew 0 clock 110.77KHz
v: height 1440 start 1448 end 1452 total 1476 clock 75.05Hz
3440x1440 (0x5e) 319.750MHz +HSync -VSync
h: width 3440 start 3488 end 3520 total 3600 skew 0 clock 88.82KHz
v: height 1440 start 1443 end 1453 total 1481 clock 59.97Hz
2560x1080 (0x5f) 185.625MHz +HSync +VSync
h: width 2560 start 3108 end 3152 total 3300 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1200 (0x60) 422.000MHz +HSync -VSync
h: width 1920 start 3888 end 3920 total 4128 skew 0 clock 102.23KHz
v: height 1200 start 1607 end 1617 total 1704 clock 59.99Hz
1920x1080 (0x61) 148.500MHz -HSync -VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x62) 148.500MHz +HSync +VSync
1920x1080 (0x63) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
1920x1080 (0x64) 148.352MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1600x1200 (0x65) 422.000MHz +HSync -VSync
h: width 1600 start 3888 end 3920 total 4128 skew 0 clock 102.23KHz
1680x1050 (0x66) 119.000MHz +HSync -VSync
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.67KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.88Hz
1600x900 (0x67) 108.000MHz +HSync +VSync
h: width 1600 start 1624 end 1704 total 1800 skew 0 clock 60.00KHz
v: height 900 start 901 end 904 total 1000 clock 60.00Hz
1280x1024 (0x68) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x69) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1440x900 (0x6a) 422.000MHz +HSync -VSync
h: width 1440 start 3888 end 3920 total 4128 skew 0 clock 102.23KHz
v: height 900 start 1607 end 1617 total 1704 clock 59.99Hz
1280x800 (0x6b) 71.000MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 49.31KHz
v: height 800 start 803 end 809 total 823 clock 59.91Hz
1152x864 (0x6c) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1280x720 (0x6d) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x6e) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1280x720 (0x6f) 74.176MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1024x768 (0x70) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x71) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
832x624 (0x72) 57.284MHz -HSync -VSync
h: width 832 start 864 end 928 total 1152 skew 0 clock 49.73KHz
v: height 624 start 625 end 628 total 667 clock 74.55Hz
800x600 (0x73) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x74) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0x75) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x76) 27.027MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.50KHz
v: height 480 start 489 end 495 total 525 clock 60.00Hz
720x480 (0x77) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x78) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x79) 25.200MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.50KHz
v: height 480 start 490 end 492 total 525 clock 60.00Hz
640x480 (0x7a) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
DVI-D-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x58
Timestamp: 29643
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3 4 5
filter:
range: (0, -1)
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
CTM: 0
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
max bpc: 8
range: (8, 16)
range: (0, 128)
range: (0, 128)
underscan: off
scaling mode: None
link-status: Good
CONNECTOR_ID: 83
supported: 83
non-desktop: 0
range: (0, 1)
The error seems to have corrected itself. You can close or delete this, thanks.
