Hey all. I am using an AMD Epyc Rome 7742 CPU in an AsRock Rack ROMED6U-2L2T motherboard which has six memory slots.
Looking at the memory configuration guidelines, six DIMMs is not a supported configuration, and it looks like 6 channel interleaving is an advertised feature of 7003 (so presumably it was not a feature with 7002).
Unless the firmware for the mainboard specifically prevents it, Rome does support 6 channels, but not in a single interleave set, so performance will be very degraded.
Best information about this I found was under “Configuration of 6 DIMMs - unbalanced” in some Lenovo documentation: https://lenovopress.com/lp1268.pdf
Quoting here:
Six memory DIMMs can be populated in a 1:1:1:1:0:0:1:1 configuration as shown in
Figure 11. This configuration follows balanced memory guideline 1, but not guideline 2. This
results in an unbalanced configuration. It results in one 4-channel interleave set and one
2-channel interleave set. Average bandwidth for this configuration was measured at 40%.
Worst case memory bandwidth was measured at 28%
EPYC Gen 3 added support to 6-channel memory interleaving when memory is populated in
the 1:1:0:1:1:0:1:1 configuration as shown in Figure 12. While technically unbalanced when
memory is populated in this specific configuration, a 6-channel interleave set can be formed, and memory bandwidth was measured at 71%.
I am running that motherboard with 6 DIMMS (2x32GB, 4x16GB) and a 7402P … all working flawlessly, except that the BIOS doesn’t ‘see’ my 16GB dimms (not even when only one pair of them is in) …
The motherboard manual doesn’t mention anything other than 6 channels being supported, and doesn’t list Milan or Rome specifically …
I wouldn’t know, my ‘workloads’ are a 32GB OSX VM that is my work daily driver, a 16GB Windows 10 VM that is my gaming rig, never really tested the performance out of it, other than using it 10-14 hours a day, both being very fast and responsive, and the thing seldom crashing on me (almost always for something stupid I did, like fiddle in the case when open and bump a PCI-E card …)
