Engenius ECW536 Review
EnGenius ECW536 Wi‑Fi 7 Access Point; Real-World Performance Review
Test date: May 25, 2026; Follow-up June 18 2026 (Firmware Update)
Client hardware: Intel BE211 2×2 802.11be adapter (PCIe)
Client driver: iwlwifi, Linux kernel 7.0.1
Test environment: RF-shielded chamber (foil-lined room, ~3 m client-to-AP distance, line of sight, Steve’s Old Sound Chamber
What we tested
The EnGenius ECW536 is a tri-band Wi‑Fi 7 access point supporting 2.4 GHz, 5 GHz, and 6 GHz radios with Multi-Link Operation (MLO). We evaluated it alongside an ASUS BE-18000 and a NETGEAR Nighthawk RS700S as comparison baselines. All APs were tested with the same Intel BE200 client in a controlled RF environment that eliminates external interference.
All throughput tests used iperf3 (10-second duration), with concurrent ping at 10 ms intervals for latency-under-load measurement. Load sweeps used UDP with stepped offered loads and 3-second warm-up per step.
EnGenius ECW536 / Throughput Results
The EnGenius was tested in two configurations:
  • MLO mode (default): Both 5 GHz and 6 GHz links active simultaneously
  • Single-link 6 GHz: Connected via 6 GHz only (320 MHz channel width)
Test Direction Streams MLO (5G+6G) 6 GHz only
TCP client → server 1 1,389 Mbps 2,307 Mbps
TCP client → server 2 3,161 Mbps 3,071 Mbps
TCP server → client 1 2,488 Mbps 2,534 Mbps
TCP server → client 2 3,026 Mbps 3,030 Mbps
UDP client → server 1 807 Mbps 820 Mbps
UDP client → server 2 1,184 Mbps 1,208 Mbps
3+ Gbps TCP in both directions the EnGenius exceeds the ~2.4 Gbps single-link theoretical maximum when MLO is active, confirming both 5 GHz and 6 GHz links are carrying traffic simultaneously. Throughput is fully symmetrical in both forward and reverse directions. This is a big deal to me because “Wifi7” has been a crapshoot in our testing.
Throughput comparison all three APs
Three-Way Comparison
Metric EnGenius ECW536 (MLO) NETGEAR RS700S (6 GHz) ASUS BE-18000 (6 GHz)
TCP 2x forward 3,161 Mbps 2,892 Mbps 2,195 Mbps
TCP 2x reverse 3,026 Mbps 3,512 Mbps 389 Mbps
UDP 2x forward 1,184 Mbps 1,297 Mbps 1,301 Mbps
Idle p99 latency 6.7 ms 12.6 ms 7.0 ms
Worst load p99 28.9 ms 28.3 ms 19.1 ms
p99 delta 22.2 ms 15.7 ms 12.1 ms
Reverse symmetry :white_check_mark: Yes :white_check_mark: Yes :cross_mark: No (6:1 ratio)
MLO support EMLSR, 2 links None detected MLD capable only
The ASUS reverse asymmetry
The most striking difference between the three APs is the ASUS’s severe TCP reverse (server→client) throughput limitation. At ~350–390 Mbps reverse vs ~2,200 Mbps forward, the ASUS exhibits a roughly 6:1 asymmetry. This was reproducible across multiple test sessions and across both 5 GHz and 6 GHz bands. Both the EnGenius and NETGEAR are fully symmetrical at over 3 Gbps in both directions.
This suggests an AP-level issue in the ASUS. I would hazard a guess to say it is likely in the downlink scheduler, TX queue management, or aggregation strategy when handling server-to-client TCP traffic.
How’s the wireless for latency for gamers?
This has come up on the forum fairly regularly. Wired is, of course, always better.
On a wired Ethernet connection, you’re used to seeing ping times of 1 ms or less to your router. The entire round trip from your PC to the router and back takes about 0.3–0.5 ms on a typical home network.
Wi‑Fi replaces that dedicated wire with a shared radio channel. Even on a perfectly clean link, every packet has to wait for a clear channel, be transmitted with forward error correction, be acknowledged by the receiver, and potentially be retransmitted if the ACK doesn’t arrive. The Wi‑Fi MAC layer adds about 1–2 ms of fixed overhead per round trip just for this channel access and acknowledgment dance. Then there’s the over-the-air propagation time (negligible at 3 m), and any queuing in the AP’s processor.
What does this mean in practice for a gamer? Here are the idle p50 latencies we measured across all three APs on a completely unloaded link:
AP Idle p50 Idle p99 Notes
EnGenius ECW536 (MLO) 2.7 ms 6.7 ms Best idle latency
ASUS BE-18000 (6 GHz) 3.5 ms 7.0 ms
NETGEAR RS700S (6 GHz) 4.5 ms 12.6 ms Different ping target
Wired reference ~0.5 ms ~1 ms Typical wired router ping
The p50 values of 2.7–4.5 ms are what you’d actually feel in a game — that’s the typical ping you’d see to your first hop. Compared to wired’s ~0.5 ms, wireless adds about 2–4 ms of baseline latency. For context:
  • A single frame at 60 FPS is 16.7 ms
  • A single frame at 144 FPS is 6.9 ms
  • The difference between 2.7 ms and 0.5 ms is 2.2 ms (less than half a frame at 144 Hz)
For MMOs and MOBAs, which are typically not bandwidth-hungry (a League of Legends or WoW session uses roughly 0.1–1 Mbps), you’ll be operating in the lightest-load regime we tested. Under those conditions (say, the 100 Mbps UDP load sweep step) all three APs delivered p50 latency between 3.5 and 4.5 ms and p99 between 7 and 11 ms. That’s well within what any competitive gamer would consider playable.
The more important concern for gamers isn’t the absolute latency, I think, it’s probably latency consistency. From own experience gaming I am more likely to notice a latency spike from 10 to 100ms on a fiber optic connection, for example, than I am a connection that is a consistent 100ms.
On this front, all three APs performed well in our tests, with the ASUS showing the best jitter control (tightest p95-to-p99 spread) and the EnGenius MLO showing the lowest absolute idle latency.
The bottom line: if you’re coming from wired, you’ll add about 2–4 ms of ping to your first hop by switching to Wi‑Fi 7. For any modern online game, that difference should be imperceptible.
The much bigger variable is your internet connection’s latency to the game server, which is typically 20–80 ms and dwarfs the local wireless overhead.
If your wifi spectrum is congested, then technologies for fast frequency hopping to try to “delete” the latency spike before it happens are much more critical. imho.
Latency Under Load
Latency was measured with concurrent ping at 10 ms intervals during each throughput test. The key metric I wanted to test here was the p99 delta.
I’m trying to nail down what happens with p99 latency and p99 under load, which indicates bufferbloat severity (thanks, Dave).
Test EnGenius MLO p99 EnGenius 6G p99 ASUS 6G p99
Idle baseline 6.7 ms 12.2 ms 7.0 ms
TCP 1x forward 22.8 ms (+16.1) 70.9 ms (+58.7) 17.8 ms (+10.8)
TCP 2x forward 23.2 ms (+16.6) 21.9 ms (+9.7) 19.1 ms (+12.1)
TCP 1x reverse 19.4 ms (+12.8) 21.0 ms (+8.8) 8.2 ms (+1.2)
TCP 2x reverse 28.9 ms (+22.2) 29.5 ms (+17.3) 9.9 ms (+2.9)
UDP 2x forward 17.1 ms (+10.5) 20.5 ms (+8.3) 10.6 ms (+3.6)
The EnGenius in MLO mode shows better idle latency (6.7 ms) than single-link 6 GHz (12.2 ms), likely because the MLO connection distributes management and data across two links. However, the ASUS has lower p99 deltas under load. I do not believe its queue management is tuned well. It is more aggressive at keeping latency down, even though its reverse throughput is crippled. Someone probably missed a decimal point.
Forward sweep -- p99 latency vs offered load
Reverse sweep -- p99 latency vs offered load
Load Sweep – Latency vs Offered Load
UDP load sweeps show how latency behaves as offered load increases. The EnGenius was tested in forward and reverse directions.
EnGenius Forward (UDP, 2 streams)
Offered Achieved p99 Latency
100 Mbps 100 Mbps 10.1 ms
250 Mbps 250 Mbps 9.6 ms
500 Mbps 500 Mbps 10.2 ms
750 Mbps 750 Mbps 16.3 ms
1,000 Mbps 1,000 Mbps 14.1 ms
1,500 Mbps 1,186 Mbps 91.9 ms
2,000 Mbps 1,184 Mbps 11.4 ms
2,500 Mbps 1,239 Mbps 10.3 ms
EnGenius Reverse (UDP, 2 streams)
100 Mbps 100 Mbps 90.7 ms
250 Mbps 248 Mbps 7.5 ms
500 Mbps 496 Mbps 13.6 ms
750 Mbps 743 Mbps 7.1 ms
1,000 Mbps 928 Mbps 8.4 ms
1,500 Mbps 1,413 Mbps 16.1 ms
2,000 Mbps 1,759 Mbps 25.2 ms
2,500 Mbps 1,960 Mbps 37.1 ms
ASUS Forward (UDP, 2 streams)
100 Mbps 100 Mbps 11.1 ms
250 Mbps 250 Mbps 13.8 ms
500 Mbps 500 Mbps 17.2 ms
750 Mbps 750 Mbps 13.7 ms
1,000 Mbps 1,000 Mbps 11.5 ms
1,500 Mbps 1,312 Mbps 8.3 ms
2,000 Mbps 1,306 Mbps 8.8 ms
2,500 Mbps 1,316 Mbps 8.7 ms
Notable: The EnGenius forward sweep shows a latency spike at 1,500 Mbps (p99 = 91.9 ms) that disappears at higher loads. This is reproducible and appears to be a real scheduler behavior. I was not sure what to make of it.
The behavior here was more pronounced in the earlier firmware which suggests Engenius is aware of it. Possibly the AP transitioning between single-link and multi-link modes at that load threshold?
The ASUS forward sweep shows the opposite trend: latency decreases as load increases, suggesting its queue management behaves differently under sustained traffic.
Forward sweep -- offered vs achieved throughput
Deep MLO Decode
We used tshark in monitor mode to capture and decode 802.11be Multi-Link Operation fields from beacon frames.
Field EnGenius ECW536 ASUS BE-18000 NETGEAR RS700S
MLD MAC address Present Present Not found
EML capabilities present Yes No No
EMLMR support No N/A N/A
EMLSR support Yes N/A N/A
SRS support No No No
Max simultaneous links 2 Unknown N/A
Recommended max links 2 Unknown N/A
The EnGenius advertises EMLSR (Enhanced Multi-Link Single-Radio) support with a maximum of 2 simultaneous links.
This is a huge deal because remember – Optional Wifi 7 features are where marketing goes to party.
Our testing confirmed both links were active during MLO operation.
The ASUS beacon does not populate EML subfields on the captured link, though it does advertise MLD capability. The NETGEAR beacon showed no MLO advertisement throughout our testing.
5 GHz Performance (ASUS only)
We also tested the ASUS on 5 GHz (80 MHz channel width) for reference:
Test Throughput p99 delta
TCP 2x forward 1,111 Mbps 51.2 ms
TCP 2x reverse 283 Mbps 7.2 ms
UDP 2x forward 760 Mbps 18.1 ms
The 80 MHz channel width on 5 GHz is a significant bottleneck compared to 320 MHz on 6 GHz, and bufferbloat is substantially worse (p99 delta of 51 ms on TCP multi-stream forward).
We tried to use this approach with the ECW to pin down bufferbloat related behaviors, but the device will simply drop packets when congested. (We think this is the right behavior – and a better behavior for gamers that probably want lowest latency-under-load.)
Test Methodology Notes
  • RF environment: All testing was conducted in a foil-lined RF-shielded chamber or Steve’s chamber (originally built as a sound chamber, repurposed for RF isolation). External Wi‑Fi signals are attenuated to negligible levels.
  • Client: Intel BE211 2×2, connected via wlan0 with iwlwifi driver on Linux kernel 7.0.1. (We also tested mediatek but that data just adds noise to this review and it doesn’t behave as consistently as intel.)
  • iperf3 server: Wired host on the AP’s LAN, connected via Gigabit Ethernet.
  • Band selection: The client connected to the AP’s strongest available band by default. The EnGenius established MLO with both 5 GHz and 6 GHz links automatically. Isolating individual bands on the EnGenius would require disabling radios on the AP side.
  • Load sweeps: UDP mode with iperf3 -b for precise offered-load control. Each step includes a 3-second warm-up and a 2-second inter-step gap for queue drain.
  • Latency measurement: Concurrent ping at 10 ms intervals during all throughput tests. Percentiles computed from raw per-packet RTT samples.
  • NETGEAR latency note: The NETGEAR’s gateway does not respond to ICMP, so the iperf3 server was used as the ping target instead. This means absolute latency values for the NETGEAR are not directly comparable to the other APs, which used the gateway as the ping target.
Summary
Category EnGenius ECW536 NETGEAR RS700S ASUS BE-18000
Peak TCP throughput 3,161 Mbps 3,512 Mbps 2,195 Mbps
Reverse symmetry :white_check_mark: Yes :white_check_mark: Yes :cross_mark: No (6:1)
MLO support EMLSR, 2 links active None MLD capable, no EML fields
Bufferbloat (worst p99 Δ) 22.2 ms 15.7 ms 12.1 ms
UDP peak 1,208 Mbps 1,297 Mbps 1,301 Mbps
Idle latency (p99) 6.7 ms 12.6 ms 7.0 ms
Bottom Line: The EnGenius ECW536 delivers excellent Wi‑Fi 7 performance with genuine Multi-Link Operation, exceeding 3 Gbps in both directions from a single client.
It is the only AP of the three tested that actively uses MLO with two simultaneous links.
Its main trade-off is higher bufferbloat under certain load patterns compared to the ASUS.
The NETGEAR RS700S wins on raw reverse throughput (3.5 Gbps) without MLO, while the ASUS BE-18000 has competitive forward throughput and the best latency management but its severe reverse-direction asymmetry (~350 Mbps) is a significant limitation for any workload with symmetrical traffic patterns.
Related, is there a reason after AC they stopped making client devices that were more than 2x2? It really feels like a shame.
Hello!
Why is MLO seemingly so difficult to implement? Like, remember trying out Connectify Dispatch (later Speedify I think) and reading about MultiPath TCP support long time ago.
For example, if there are three wireless access points using the three bands separately with each one having its own dedicated band and there is a client device with three wifi adapters each configured for one of the three dedicated bands separately, what software sorcery would be needed to optimize the throughout for bandwidth sensitive traffic or to optimize the latency for latency sensitive traffic? What will the OS do if they are bridged, what about setting the priority (metric), what about smb multichannel or LACP, etc…
(Speedify works as a VPN (re)assembling the packets and supports combining cellular connections too. Obviously latency is high as the )
Disclaimer: Not affiliated with Speedify!
Because they are aiming for something that is more efficient than encapsulating all packets into what is essentially a vpn then doing routing in software at the IP level of the network stack.
Mlo works at the MAC level, a part of L2, data link layer. So in simpler terms its handled by the wifi chipsets independently, and they have full control over the actual data transmission over the radio, since both chipsets at each end switch their operation to this mode.
Speedify and every other wan bonding service or software work at L3, network layer. They kinda have to since they have to move the “split” traffic over a conventional network between the two endpoints of the tunnel.
Mlo is basically wifi version of lte or 5g carrier aggregation, and its kind of long overdue. We had carrier aggregation for ages at this point
:cookie:
(since you asked for it in the video)
Power mostly and complexity of the chipset. You can reliably do up to 5 gigabit on the newest Intel be211 with the very best AP.. in short bursts. 3.5gb sustained.
Unifi has a weird little USB adapter iirc is 3x3
Hi Wendell! I’ve been looking for wifi 7 options that don’t require cloud management/ online account. I see that engenius has the Fit line that is local only, but that just goes up to wifi6 (ax). Do you know if their “cloud access point line” like your ecw536 can be run without that, as local only?
For context I’ve currently got an Aruba 500 series IAP for my primary wifi, and an asus be7200 for a home router and the wifi on it is only for my streaming handhelds.
You Rock,
Brian
typically you can run it locally “eventually” – its kinda like unifi in that regard – but I haven’t tested that on this model.
Fit is also online but (somewhat, there are asterisks) “supports” offline with a controller. You can add your own cert and spy on exactly what the AP is doing. I haven’t seen it do anything nefarious.
