Emulate/parse traditional/MegaRAID disks?
So this might be a bit of a weird one.
I am assisting with a case where a server was seized and we’re tasked with pulling information off of it. The server has a traditional MegaRAID card with some form of striping RAID.
We have an image of each hard disk in the set that was captured forensically. We are expecting VMFS datastores since it is a virtual host. If at all possible, we want to work off of the images taken and not interact with the server directly (to avoid spoilation). As far as we know, the disks are unencrypted.
Has anyone had luck with either emulating a traditional RAID adapter or parsing multiple disk images in a RAID 5/6 into a single disk image?
This may be of interest…
Linux’s mdadm can read LSI MegaRAID signatures and assemble the array just fine.
This is exactly what I’m looking for! I should be able to mount the e01 files into loopback and get pull a full array image to mount. Thanks!
If mdadm doesn’t work, I’ve had luck with dmraid with an old LSI MegaRAID 320-2E using the ddf1 metadata format:
# dmraid -l
asr     : Adaptec HostRAID ASR (0,1,10)
ddf1    : SNIA DDF1 (0,1,4,5,linear)             <--------
hpt37x  : Highpoint HPT37X (S,0,1,10,01)
hpt45x  : Highpoint HPT45X (S,0,1,10)
isw     : Intel Software RAID (0,1,5,01)
jmicron : JMicron ATARAID (S,0,1)
lsi     : LSI Logic MegaRAID (0,1,10)
nvidia  : NVidia RAID (S,0,1,10,5)
pdc     : Promise FastTrack (S,0,1,10)
sil     : Silicon Image(tm) Medley(tm) (0,1,10)
via     : VIA Software RAID (S,0,1,10)
dos     : DOS partitions on SW RAIDs
Disk Internals have a RAID recovery tool too if the Linux tools don’t work out.
I’ve never used the RAID one, but their filesystem tools are awesome. I assume the RAID tool is of similar quality.
Also, I think Testdisk has some capabilities regarding RAID signatures, but I can’t remember. I may have been using that for a mirrored array to find the partitions.
