Elementary OS Nvidia Screen Tearing Need Help
I am using elementary OS Freya 64 bit which is installed on a MSI GS60 2QE laptop. The screen is 1080p as well with 8GB of RAM and a i7.
Everything runs great, I even managed to install the WiFi drivers.
However, my laptop has Intel HD 5500 graphics as well as a 970m. I want to use the 970m but when I change the drivers over to Nvidia I get screen tearing and it is driving me nuts. The Intel GPU works fine, no tearing at all but I really want to just use my 970m instead.
I have tried so much over the last 2 days to get the screen tearing issue fixed but no luck.
Here is what I have tried:
  • Changing the nivida pipe line
  • Changing the Xorg config and moving it to the Nvidia area
  • Tried to use Compiz to alter the refresh rate but no luck
  • Changing the environmental variables
And much more...
Any ideas to where I can look?
Thanks.
Its a known issue for years: https://devtalk.nvidia.com/default/topic/775691/vsync-issue-nvidia-prime-ux32vd-with-gt620-m-/
Its close to being fixed though, check page 3 or 4 for the current status of the issue, there is a patch already in 4.5 kernel but more things need to be done in order to the issue to be fixed (xorg and nvidia driver patch).
Try compton, it got a lot of options and "vsync" methods
