I am playing it without issues but I don’t use any launch flags and have made “shortcut” using steam.
I use proton-ge-custom that comes with garuda linux. That is my only non default configuration I can think of
If i remember the mods installation in the games main directory you have .exe file and then there is special mods directory that contains .dll and config file with password(use some random character generator to get unique long password with your friends).
Only issue is if you have connection issues with host they may need to remake the game(full restart)
I got it working, but I had another question if you know the answer. How do you run two programs in the same proton prefix or how do you run Proton in Lutris.
I’m trying to run Elden Ring Seamless Coop and Cheat Engine. I can run and use both with Lutris and GE-Proton7-24, but mangohud HUD labels VKd3d as Wine 7.0 and the performance is worse.
If I add non-steam game for cheat engine, mangohud HUD labels VKd3d as Proton7-24 with better performance, but cheat engine can’t find the Elden Ring .exe.
Wish Steam would let you select prefix in the steam gui
Basically you need the same prefix and same version of wine running for the .exe’s to see each other, but steam creates a new prefix for any non-steam game you add and I don’t know how to change the prefix location to the Elden Ring Prefix.
BTW I renamed seamless coop .exe to start_protected_game that way I can just click play on Elden Ring in steam to load seamless coop mod.
I’m having the same issue with Horizon Zero Dawn when it comes to performance. Horizon Zero Dawn runs great with steam proton, but when I use GE-Proton7-24 in lutris the performance is a lot worse. Reason I would use Lutris or Heroic Game Launcher is for the drm-free edition of Horizon Zero Dawn on GOG.
How did you fix this issue?? I can’t find this problem anywhere online, seamless coop used to work great on my steam deck and now it’s crashing everytime I use the in game co op items. Please help me can’t find a resolve anywhere
